chine walking
trim tabs will work. should not need any more then 12 inches wich is the smallest you can get with k kieffifere. don't go any longer boat is to small.
Treadwell
Treadwell
Member #2 ....Jeeezz
Chine walking is a result of flat water
Look Fast *** Sold Sold Sold *** ... F2 Cigarette Top Gun in OSO Classifieds
You may want to ask Darin @ Houston Propellor but I've heard that chinewalking can sometimes be related to too much prop diameter. I'm not an expert but have heard that can be one of the reasons....how's the bottom of your boat?
Well...this should get you started! Good luck and let us know what you find is the culprit.
Enjoy the show
Do you have a little toe in on the drives? About 1/2 inch difference between the nose cone and the end of the prop shaft might help.
Are you spinning in or out?
