Irratic Trim gauge???
Old 07-01-2003, 08:03 PM
Aka8953121
Question Irratic Trim gauge???
My trim gauge is very erratic when underway. It bounces a lot and can bearly be read. Anyone know what might cause this? Is the gauge shot?
TIA
joe
Old 07-01-2003, 08:04 PM
Aka8953121
Default Correction Erratic Trim Gauge
sticky fingers!
Old 07-01-2003, 08:32 PM
Registered User
36spectre's Avatar
Bad ground or loose wire at the gauge or the indicator. Otto
36spectre is offline
Old 07-03-2003, 09:22 AM
220EagleXp's Avatar
My trim gauge does the same thing, I will be checking wires too.
220EagleXp is offline
Old 07-03-2003, 12:05 PM
SSComp's Avatar
The senders go bad quickly. Should be a set of make female disconnects. Leave open then jump. Trim should go full up then full down.
Also run you drives up and down looking for dead spots on the sender. If you need to replace the sender is is a SOB if you do it correctly. I just snip the wires at the sender, splice, and seal in silicone.
Good luck
SSComp is offline
Old 07-03-2003, 01:36 PM
seanclong's Avatar
Good luck
You aren't kidding about the PITA replacing a sender can be. I just had a trim sender replaced to the tune of $438.00. I believe they have to take the drive off... I like the trim and splice method.
seanclong is offline
Old 07-03-2003, 01:37 PM
220EagleXp's Avatar
If it costs that much to replace I would just go with a mechanical setup.
Old 07-03-2003, 01:44 PM
SSComp's Avatar
Splice and go.
SSComp is offline
Old 07-04-2003, 07:07 AM
EricF
Default Trim Gauge
The trim gauge works on ohms of resistance between two contact points. Before changing your trim gauge try removing it (as much as the wires will allow) from the assembly, being VERY careful not to break the two stainless machine screws, and clean the contacts gently with a small wire brush, make sure there is enough tension between the contacts and lube with an electronics grease. Do yourself a favor and use “Never Seize” on the machine screws when re-assembling. If it still doesn’t work, “Stainless Marine @ 305-681-7893” manufacturers a fairly nice and relatively inexpensive mechanical trim indicator that is pretty user friendly to install and keep serviced.
Eric Froberg
Old 07-04-2003, 05:10 PM
buckknekkid's Avatar
Default Re: Trim Gauge
Eric Froberg
Advice from the MASTER!!!!!!
buckknekkid is offline
DesertRage
Wanted
4
08-19-2008 04:55 PM
86formula242ls
05-23-2007 04:40 PM
kennyo
4
08-30-2006 09:10 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
JTB
4
04-15-2003 03:42 PM
Quick Reply: Irratic Trim gauge???
