If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Lynch Mob Racing Platinum Member Hot Duck's Avatar
    My Boats:
    39' Cigarette Top Gun, Donzi 22 Classic, 36 Yellowfin
    Join Date
    Feb 2001
    Ocean City, MD
    Instead of switching drives just for a test run, why not just switch the props and put them on the opposite drive than normal. Then just put the controls in reverse to go forward and vise versa. If you like the results, then make the change the correct way. To change the rotation so that the controls work properly, all you would need to do is change the position of the shift cables rather than swapping the drives. Right? If you have Bravo's, I don't see why this would not work, but if you have SSM's or TRS's I am not sure.
  2. #12
    Registered Sean's Avatar
    My Boats:
    20 Donzi Minx, 18 Donzi Classic
    Join Date
    Oct 2000
    Darien, CT
    you are correct for the bravo setup, but i don't think it is advisable on a transmission motor...i believe you would be essentially running one of the transmissions in reverse and I don' think that is recommended for high speeds...
  3. #13
    Mad Hatter
    Originally posted by catmando
    Didn't know Cigarette made an 86' boat.
    1986 abreviated smart a$$
  4. #14
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ..........32........... Active Thunder
    Join Date
    Oct 2000
    Originally posted by Too Old
    I just had this discussion a couple days ago with a guy who has a good deal of experience with older Cigarettes. His recommendation was that I give it a try. He felt it would make the boat faster.
    Swapping TRS drives from side to side is pretty simple so I think it's worth a try.
    Fred, wouldn't you have to actually put it in the water to find out how fast it is now before you switch um?????
  5. #15
    Join Date
    Oct 2000
    I would think it be not good advise to swap the rotation on transmission drives, since the drives have already worn in the gears as to which way they rotate. Could cause the life to be shortened.
    But the roll of thumb in props turning in will give you stern lift and props turning out will give you bow lift. And with my luck and a 50/50 chance of getting the statement wrong, it could be the opposite
    When you do flip them, so to speak, the steering gives a feeling of being very loose with possible speed increase.
    Speed increase with stability in steering not good...........just my $.02
  6. #16
    Join Date
    Jan 2001
    ST. Louis, MO, USA
    Velvet drives are not rated for full power in both directions. You'll burn it it fast if you just switch props.
  7. #17
    I have #6's on my 99 Top Gun and the factory had the props turning out...I turned them in and the whole dam boat came to life. It have it ass end lift and I picked up around five to six miles per hour. Docking it was not much more difficult, unless you are a poodle like the Phantom!!!!
    I turn them back out every now and then and the boat handles and rides better because it is in the water but again, I lose that speed.
    Give it a try and experiment!
    DMan...and the D is for turn the dam drives in!!!! Thats two D's
  8. #18
    Mad Hatter
    He's going to try it.
  9. #19
    Join Date
    Apr 2003
    my trs merc gear boses have a 10 plate clutch operated by a hydrolic pressure plate for forward gear. Reverse is run through a configurtion of worm gears. If you have this setup do not swap the props and run them in reverse.
Similar Threads
  1. Changing prop rotation
    By Jim Diesel in forum Drives and Lower Units
    Last Post: 06-07-2007, 11:13 AM
  2. Changing Cigarette....
    By GLH in forum General Boating Discussion
    Last Post: 06-12-2006, 09:54 PM
  3. Why Don't The Speed #'s Add Up?
    By FASTERDAMITT in forum Formula
    Last Post: 07-25-2004, 11:46 AM
  4. Cigarette Speed Boat Charm 14K Gold 12.4grams
    By Organdonor in forum General Boating Discussion
    Last Post: 11-25-2003, 12:51 PM
  5. Anyone running speed masters on a Cigarette Mistress
    By Doug in forum General Boating Discussion
    Last Post: 09-26-2003, 08:58 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
