View Poll Results: What oil?
Royal Purple
23
11.79%
Mobil One
112
57.44%
Dyno Oil
15
7.69%
Other Synthetic
45
23.08%
Voters: 195. You may not vote on this poll
What oil are you running?
#51
Originally posted by force 320
do you realy have to run a drive oil in the drives or are they just worried about an enviromental thing
#53
Originally posted by bn
I can understand not using Merc oil, but why do some of you prefer the multiviscosity over the straight weight? Merc seems to reccommend the straight weight as the next best thing to their own oil.
(1) There is only one true synthetic oil out there that offers straight weight oils w/ detergent in 30W or 40W (Royal Purple). Redline's 30 & 40 are non-detergent for racing only (to be changed after EVERY race).
(2) The reason Merc does not recommend the multi-weight oils is that conventional dino oils require additivies to make them multi-weight. Syn oils require very little or no such additivies unless you are using an oil with a large "spread" such as 5W-50.
That said, from what I've heard, the straight-weight blend that Merc has is the best idea of all (except that it is not synthetic). It's like having multiple sizes of ball-bearings. If somebody make this oil in a syn version, I'd be all over it. What I don't know is if creating this "blend" is as simple as pouring two different straight-wt oils into the same container. I would guess not as it seems like the heavy stuff would always go to the bottom.
#58
KY Jelly has never let me down
aborbs any water you may have in your motor too
works grear in the drive too
A favorite for years KY Jelly by Johnson & Johnson is the No.1 lubricant available today
