If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Registered JUSTONCE's Avatar
    My Boats:
    Join Date
    Oct 2002
    tropical Cleveland OH
    sometimes its just the right angle where the fuel pushes the float a certain way. Mine has never died from entry but a few big ones did make the motor miss a beat or two.
  2. #12
    Enjoy the show VIP Member Ron P's Avatar
    Join Date
    Feb 2001
    The Joisey Shore
    It just need to pause for a moment to say OUCH!
  3. #13
    Registered Donzi 1's Avatar
    My Boats:
    1998 Donzi Classic 22
    Join Date
    Jan 2001
    Columbus, OH
    You said you checked all your electricals, but I had the same thing happen on my carbed 454 MAG in my 22 Donzi this past weekend. I'll post just to give someone else my experience.
    Boat hit very hard. Engine shut off with the key buzzer now sounding. I had power to the key and to the starter as like yours, the engine turned over fine when I tried to restart. My next thought was a problem with the coil and the plugs were not getting fire. Checked all wire connections to the coil and to the distributor. All appeared OK. Has a last ditch effort, I crawled up under the dash and sure enough, found a wire that must have been a hot lead to accessarys and the coil. It had seperated from it's crimpted round piece that was still attached to the ignition switch. I pushed the wires back into this piece and she started right up. We idled to a marina where I was able to buy the needed parts and borrow tools to make the fix. (Note to Donzi: Use a longer screw on the switch when your trying to put 6 of these connections on the switch terminal please.) They had this little bitty brass screw trying to hold 6 of these power leads! Anyway, replaced the small screw with a longer one and reattached all the connections to the ignition switch. No further problems.
    As stated by more professional folk than I, your problem appears to be with your carb float. Just thought I'd share what happened to me as it had very similar results to yours.
  4. #14
    Join Date
    Mar 2002
    Mentor , Ohio
    Did this phenomenon occur whilst proceding toward the bar ,or during your journey back from said establishment ???
    May need to evaluate the "wingnut" behind the steering wheel !!!
  5. #15
    Registered IDRPSTF's Avatar
    My Boats:
    Whatever you missed your payment on
    Join Date
    Sep 2001
    In your driveway while you sleep
    I have turned a few airplanes into gliders that way. The float litterally flats to the top and chokes the engine out. Neg G dives will do that. It may not have been the slamming down, it might have gone out on the way down.
  6. #16
    Mike J
    1 Motor = Fix it now.....
    Mike J.
  7. #17
    My Boats:
    1991, Baja, 270
    Join Date
    Aug 2001
    Mentor, Ohio
    Now that you mention it, maybe it was the loose nut behind the wheel, I'll have to check that tonight and let you know.
    Maybe, if I don't fix it I'll just ride on the Saber for the poker runs.
    To everyone else that had intelligent things to say, I appreciate your help.
Similar Threads
  1. Smooth landing!
    By kennyo in forum Baja
    Last Post: 08-16-2006, 10:15 PM
  2. you know what kills me???
    By jb in forum General Boating Discussion
    Last Post: 01-09-2004, 02:57 PM
  3. Motor out of tune after hard run...
    By TomZ in forum General Q & A
    Last Post: 07-15-2002, 08:37 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
