Trailer axle alignment
Looks like we found the problem. The center pivoting spring hanger/shackle for the rear axle was rotated on top of the spring. I guess this happens if the trailer bounces high enough (without the boat on it). They are jacking the trailer and boat up now to remove the bolts and rotate it to it's proper position.
Bruce...
Bruce...
outlawntexas, I was just about to tel you to check that .... If you get 2 axels off the ground the shackles can flip real easy and it realy through is out of wack !
I am glad you figured it out but I was also going to offer to keep your boat for you for a couple weeks or months if needed till you fixed it !!
Just another Toy
15
03-11-2008 06:15 PM
