Throttle Up
Charter Member#157
Throttle Up
Has a couple?
Can you PM back answers please?
What does it take to test your props?
What is the testing price?
How much for Hydromotives 28 or 30's?
Specs are as follows:
1999 Advantage 28' Sportcat
Twin stick 502's. Only add on is Vortec K/N air cleaners.
Weight is an approx. 5200-5400Lbs dry
Stock 1.5 LWP bravo 1's
Currently turning 28 bravo 1's
Never had anything done to the props or engines.
Able to bump the rev limiters 90% of the time.
High humidity of course makes it impossible.
Hitting speeds of 87-89 with no weight and less then 20 of fuel. Factory reported a best of 91 3 years ago. But no verification.
Average of 79-82 with average to high weight and people aboard.
Semi hard to plan would like better.
Two things I want, even if it I have to have two sets of props.
I would like one set for great hole shot. Current lake has lots n lots of no-wake zones.
Also would like a high-speed set of props.
Current ones surface all around running as they are still in great shape.
So I am mostly on the hunt for a High speed set.
To conclude; How long to get a pair send to Minnesota?
How long would I have to test?
How many sets do you allow to test before buying?
Do I HAVE to purchase one even if the testing does not prove to meet my goals?
Last, after testing do I buy the tested set or do you have test props then NEW props?
Thanks, Hugh
Thanks, Hugh
This Cat is trying to keep up with the Big Dogs
Hugh,, Julie and the Guys at Throttle Up,, will be able to hook you UP!!!!! I bought a set from them last month, and everything was GREAT, and Delivered on Time!!! Julie's Tele# 877-842-6855
We broke a blade on a prop just before the Daytona race this year. Throttle Up made us a replacement and delivered it to us in Daytona the day before the race. Great service.
Will
Lynch Mob Racing
Will
Lynch Mob Racing
Charter Member#157
Thanks guys for the positive word.
And thanks for the phone #
I talked with Julie yesterday about the boat and my prop needs and goals.
She is looking into getting a set of hydro's fitted for my standard bravos.
I look forward to doing some testing in the next couple months before winterizing
Time will be tight, but would like to get things worked out by nov 1
