Originally Posted by shawn
(Post 2091573)
Michael, you would be surprised at what I do.
Hope your winter went well. When do you think you will have your boat on the Bay? Winter was ok but to long. When it be over? On the water by May how about you? Michael |
Michael, I expect to be on the water a little before Memorial Day. Usually its too cold and windy and I have a fair amount of work travel scheduled before then.
Maryland Mark, I bought the Eisenglass from Ted's lead. http://www.outdoortextiles.com/home.php I had my sheet metal shop make up aluminum plates to sandwich the Eisenglass and mount to the area above my openings. One plate had Pem Studs (1/4 x 20) and the other had through holes. I used Stainless studs and wing nuts. I used strapping material to cross over each other and hold up the panels when not in use, similar to the way cruisers hold up their Eisenglass. I use bungee cords to hold down the bottom of the panels. I used brass grommets to make sure the panels did not tear through. I used Tapcons to mount to the assembly to the brick wall. Any local sheet metal fabricator can make the bars, I used 2" wide by 48" ( I think) inch long pieces and placed the mounting hardware on 12ish" centers with one 2" from each end. I used .060 thick aluminum. |
