Eisenglass Source
Old 04-13-2007, 03:48 PM
Originally Posted by shawn
Michael, you would be surprised at what I do.
Hope your winter went well. When do you think you will have your boat on the Bay?
Now you have scared me a little
Winter was ok but to long. When it be over?
On the water by May how about you?
Michael
mmwalters is offline
Old 04-15-2007, 12:04 PM
Michael, I expect to be on the water a little before Memorial Day. Usually its too cold and windy and I have a fair amount of work travel scheduled before then.
Maryland Mark, I bought the Eisenglass from Ted's lead.
http://www.outdoortextiles.com/home.php
I had my sheet metal shop make up aluminum plates to sandwich the Eisenglass and mount to the area above my openings. One plate had Pem Studs (1/4 x 20) and the other had through holes. I used Stainless studs and wing nuts. I used strapping material to cross over each other and hold up the panels when not in use, similar to the way cruisers hold up their Eisenglass. I use bungee cords to hold down the bottom of the panels. I used brass grommets to make sure the panels did not tear through. I used Tapcons to mount to the assembly to the brick wall.
Any local sheet metal fabricator can make the bars, I used 2" wide by 48" ( I think) inch long pieces and placed the mounting hardware on 12ish" centers with one 2" from each end. I used .060 thick aluminum.
shawn is offline
Frequency
10-27-2006 10:31 AM
Bubbletop409
1
06-05-2006 06:24 PM
Sean
12-06-2004 10:34 AM
Zanie
5
12-13-2003 06:28 PM
Quick Reply: Eisenglass Source
