OT- 2004 Ford GT-40
OT- 2004 Ford GT-40
Just saw a segment on speedvision on this car coming out soon from Ford.
500HP
Price: "While the final MSRP won't be released until just before the car goes on sale, Lyons told dealers that early guesses of $250,000 are way off. According to Lyons, the MSRP will be "substantially less than $150,000," which, he explained, will make it substantially less than its nearest supercar competitor the Ferrari 360 Modena."
This rig is the shizz as our CA buddy says what do you guys think?
http://www.fordvehicles.com/fordgt/home.asp?bhcp=1
500HP
Wheel Base (in): 106.7
Overall Length (in): 182.8
Overall Height at curb (in): 44.3
Overall Width (in): 76.9
Front Track (in): 63
Rear Track (in): 63.7
Weight Distribution (ft/rear): 43/57
Overall Shadow (sq ft): 96.8
Approach Angle (deg): 9.2
Departure Angle (deg): 14.0
Seating Capacity: 2
Leg Room (in): 44.6
Head Room (in): 35.4
Shoulder Room (in): 57.7
Hip Room: 57.8
Passenger Volume (cu ft): 52.8
Interior Volume Index(cu ft): 53.2
Engine Type: DOHC, 4 valves per cylinder, supercharged V-8
Engine Displacement (L): 5.4
Bore/Stroke (mm): 90.2x105.8
Displacement (cu in/cc): 330/5409
Compression Ratio (in/mm): 8.4:1
Material: All Aluminum
Horsepower @ RPM: 500@6,000
Torque @ RPM (lb ft): 500@4,500
Horsepower Specific Output (hp/liter): 92.6
Torque Specific Output (lb ft/liter): 92.6
Recommended Fuel: 91 octane (premium)
Fuel System: Sequential multi-port electronic fuel injection -(SEFI) with dual injectors per cylinder
Oil Capacity with Filter (quarts): 10
Usable Fuel Capacity (gal): 18
Type 6-speed manual
Gear Ratios 1 - 2.61
2 - 1.71
3 - 1.23
4 - 0.94
5 - 0.77
6 - 0.63
Final Drive Ratio 3.36:1
Gear Synchronization 1 - Triple
2 - Triple
3 - Triple
4 - Triple
5 - Double
6 - Double
Chassis/Steering/Brakes
Drivetrain Layout Rear-wheel drive
Front Suspension Double Wishbone
Rear Suspension Double Wishbone
Steering Type Rack-and-Pinion
Steering Ratio 17:1
Turns Lock-to-Lock 2.7
Turning Circle (Curb-to-Curb) 40 ft.
Brake System Vacuum Power Assist
Front Brakes (in) 14.0
Rear Brakes (in) 13.2
Seating Capacity: 2
Leg Room (in): 44.6
Hip Room: 57.8
Type 6-speed manual
2 - 1.71
3 - 1.23
4 - 0.94
5 - 0.77
6 - 0.63
2 - Triple
3 - Triple
4 - Triple
5 - Double
6 - Double
Steering Ratio 17:1
Member #9
Would make for a great cop car hey Troutly
I like it but wish they would have brought back the old style GT350's
Member of the Liquid Jungle
