These prop cases are nothing short of high quality. I personally own 2 of them and use them all the time. When carrying or transporting, there is no need to worry about damage to the props.
Call Chicago Case for a catalog or give me a call and I can hook you up with some. You will not be disappointed! In fact, Phil at Lipship uses them along with several of his customers. Little Tommy (H) 262-827-8827 (C) 414-349-8567;) ;) |
I also have one from Chicago case because that`s all I need (for now anyway). They also make some nice gun cases, I have one of those as well. Here`s a link.www.chicagocase.com
SO.....what's the skinny on the prop boxws here. Who actually has them..............or do they have different manufactures. Or does everyone work where they have cases that are converted?
Does one case fit all props? Or do you need a different box for 3-blade, 4-blade and etc. |
1 Attachment(s)
enticer; depending on your diameter there is a case for your needs!!
try http://www.mooringlines.com/ their service is supposed to be great
FYI: The cases sold by http://www.throttle-up.com and by http://www.mooringlines.com (a.k.a. Top Knot) are identical. Same cases. Thoroughly recommended.
It appears like they are manufactured by Chicago case, see http://www.chicagocase.com/std_musical.html. The cases sold by Throttle-Up and Top-Knot come in two sizes. The standard Bravo I prop takes the smaller size. The 5blade Hydromotive needs the larger size. |
top know has them in stock and will ship 'em right out for ya!!!...hummm...those props and cases look familiar!!!so does that boat! :D
good eye joe. have jason call mr about the gear cases.
i will
chicago case also makes Craftsman toolcases for sears.i saw them in the hand tool cat.
cya lucy |
