Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-16-2003, 09:41 AM   #21
32storm's Avatar
Boatless....
Hustler has been using Arnesons since the 80's. They would set up 32's with moderate HP big blocks with Arneson's for performance in the 80's.
Cuda the "wow" factor rooster tail is there with Arneson's even when cruising at slower speeds. always are crowd pleaser.
32storm is offline   Reply With Quote
Old 11-16-2003, 09:58 AM   #22
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
super termoli- what kind of boat is that by the way and what are the specs. looks cool, do you have any other pics.
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Sponsored Links
Old 11-16-2003, 11:36 AM   #23
SLINGSHOT's Avatar
1994 McMANUS COMANCHE
my bro has a 39 express cat with arnesons,,, handles well around docks and in reverse runs gtrat straight too!! could be because its wide
SLINGSHOT is offline   Reply With Quote
Old 11-16-2003, 11:42 AM   #24
bob
Charter Member #40
Sutphen 390
Super Termoli/ thanks for all of the info! I still don't quite undersatnd why trim angle wouldn't be important with this setup? I have 4's on boxes and the shafts are about 1" above the bottom on a 39 Sutohen. If I run with the shafts at -2 trim and +2 trim the hull definetly takes a different set and handles differently. At 65+ the drive "torpedo" upper half is exposed. This hull has very good lift characteristics both front and rear. The mfg has tried to race with Arneson's and changed back on their 33, primarily due to handling so I am told (Basically the same bottom). I believe the trim angle played a part, especially when flying the boat and re-entry characteristics. I have a friend with the hull identical to mine with 8's and the wetted running surface is definetly greater than mine at any speed. Don't get me wrong, I am sold on the design of the various surface drives, especially on efficiency and simplicity...especially on cats. I just question the application on a v bottom if you are trying to maximize speed and handling. As far as docking goes, my friend has a counter rotating setup and in reality it probably isn't any worse than my setup. He is spining out and I in. Neither very friendly at the docks but as far as I am concerned the price to be paid. Bottom line, from my perspective, on a v if you want to run these surface type drives there are operational savings to be had, at a potential operational cost.
bob is offline   Reply With Quote
Old 11-16-2003, 11:51 AM   #25
super termoli's Avatar
Too old, you're right. I believe the new ASD 6 can be run with up to 750hp but again it's more a question of torque than anything else. I mentioned around 700hp in my first post, saying that with this sort of power you should really run a SSM6 unless you like trouble. So in those cases, ASD 6 can advantageously replace the Speedmaster both in terms of cost and performance. Many people are actually running around 700hp because this is a number which can be obtained from a blown big block while keeping it reasonably reliable by running tame boost pressures. However, if you have more power, say 1000s, then you would need to step up to the ASD 8. They are much more expensive but I believe Twin Disc are working on a new version (like they did with the ASD 6) which will be simplified as a replacement for the Speedmaster and much cheaper.
Sutphen30, the Trimax is a fantastic drive, the most reliable of them all because it has the smallest number of moving parts. Its simplicity is truly beautiful and if you look at the photo, only stainless steel is in contact with water. All hydraulics and steering is inside the hull and accessible from inside for servicing. If you look at trim tabs, only the SS piston comes out while the hydraulic cylinder and lines are inside the hull as well. No leaks, no electrolysis, no galvanic corrosion... However, the big problem is that the transom needs to be configured for Trimax and that platform is necessary. It is actually very practical but it forces the manufacturers to tool up differently and modify their molds and this is why so few manufacturers are using Trimax. Even though the drive itself, once you've tooled up, is cheaper than a Bravo XR. This drive is manufactured and marketed by ZF Marine so go to www.zf-marine.com and look for trimax under their propulsion heading...
bouyhunter, glassdave is right. those are ventilation ducts which bring air to the props when the boat is accelerating from standstill. This cavitates the props or "breaks" the prop which allows you to pick RPMs up faster and thus accelerate faster. As props start to turn faster, there is a pressure-sensitive flap in the duct which is shut down as the back pressure increases. This means that the amount of air is regulated at high speeds to increase efficiency. This is one of the advantages of Trimax over Arneson in terms of performance. Arneson has the props sitting relatively deep in water at standstill with no air being channeled to them which makes it difficult to "break" the prop and accelerate fast. Then, at high speeds Arneson has props on the surface which causes too much air to be sucked in and it looses in efficiency. In other words, with Arneson, props are being well aerated when they do not necessarily need it and are starved of air when they need it, a thing Trimax has corrected and put the right way around. Another thing about that boat on the photo is the fact that it has underwater exhausts which come out under the hull and forward of the drives. This means that when the Trimax ducts are closed off at speed and drives covered by that platform, props are still aerated by exhaust gases. In addition, this provides extra transom lift and hides any smoke you may get from those diesel engines.
Finally glassdave, that boat is the new Hustler "Esprit de Soleil". It is 50' by just over 10', powered by 4 Yanmar 440hp diesels running through ZF 2-speed trannies. It is approx. 23 000lb dry and it will run close to 80 mph and accelerate to 60 in 10 seconds. It gets on plane in 3 to 4 seconds, as soon as the turbos kick in. It's a tank and it's what you need for endurance runs.
super termoli is offline   Reply With Quote
Old 11-16-2003, 12:20 PM   #26
glassdave's Avatar
WOW . . . nice . . . very nice. feel free to post more pics of that . havent seen one of those yet. thanks for the info.
Old 11-16-2003, 12:40 PM   #27
here's one pic of it running...
Old 11-16-2003, 12:46 PM   #28
interior: approx. 6'10" of headroom, stand-up shower, cherry wood and ultraleather interior, corian, centralvac, flatscreen, DVD, VCR, CD changer, Sony X-plode amps, 1000W, full galley with a double burner, microwave, top loader fridge, icemaker, cedar-lined closets...
Old 11-16-2003, 12:47 PM   #29
Cigwillie's Avatar
1989/99 Cafe Racer
Great info. guys..
"Minimal radar signature thanks to the almost total absence of the rooster tail typical of other surface drives. "
This is in the advantages section of the ZF Trimax site. Why is this an advantage? Does a rooster tail block your own radar? Don't you want other boater's to "see" you better? I have very limited experience with radar (other than speeding tickets )
Cigwillie is offline   Reply With Quote
Old 11-16-2003, 12:48 PM   #30
more interior with the entertainment center...
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Blueprinted bottoms? Rebel_Heart Fountain 10 05-05-2008 12:42 AM
If you like V-bottoms....... dank368 General Boating Discussion 23 10-21-2005 09:57 AM
fast v bottoms warlocking General Boating Discussion 0 10-10-2004 10:07 PM
Why So Many New 39 V Bottoms??? Buddy OO General Boating Discussion 8 08-15-2004 03:47 AM
42 hull bottoms later Fountain 0 10-01-2003 03:10 PM
Search Engine Optimization by vBSEO 3.2.0
