If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    GLH is offline
    Platinum Member Platinum Member GLH's Avatar
    My Boats:
    Join Date
    Dec 2002
    Burlington, VT
    I've built a few homes and it is a portion of what I do for a living. Call if you have some questions I could go over how the new home financing options work around here at least.
    G.L. 802-734-8284
  2. #12
    Registered dhlaw's Avatar
    My Boats:
    2001 Top Gun T/S, 2002 Gladiator
    Join Date
    Feb 2003
    New Smyrna Beach, Florida
    I agree with Open72, you need to give Jassman a shot at the plans. He is an honest and nice guy..... and a avid boater!!
  3. #13
    Gold Member Gold Member RebarBox's Avatar
    My Boats:
    05' Cobalt 343, 28' Cigarette a.k.a (Bicycle), 91' Ciglett, 08' Tahoe 215, plus some other crap.
    Join Date
    Apr 2003
    Grove, Oklahoma
    I'm currently building a new home myself. A little differant than you, Hammer, as I sold my house first and am living in a rented duplex.
    All I had to show my banker is an accurate estimated cost to complete and a simple floor plan. They provided me with a Construction Loan good for a year. We set up a seperate 'construction account' checking account. I need money, I just call the bank and tell them to deposit $10,000 or $20,000 when I need it. They bill me interest, only the money I have used, on a monthly basis.
    Doing the work yourself is a real money saver. I should have about $155 K in mine and the banks appraiser valued my competed house and shop at $219 K - and thats only off a floor plan and a front elevation view of the completed house.
    Be prepared to work your a$$ off, I haven't seen a weekend to myself in 5 months now and will not see one until mid-Feb. If you work a full time job now, it's like having TWO full time jobs.
    Remember, If you do your own contracting or even hire a general - 'it ain't so, unless it's in writing!'
    Good Luck!
    'Inez - Get them panties off' Quote - Roy D. Mercer
  4. #14
    Registered JPD Motorsports's Avatar
    My Boats:
    scratching the surface!
    Join Date
    Sep 2003
    Flower Mound, TX
    Take your blue print to a bank that does construction loans, or a bank that are familiar with you. They can give you a bid on the print. Also find you lumber yard suppliers, most will give you a lumber bid, boor bid along with window bid. Also find out who the framers are that this contractor is using and check jis work visually. Make sure you get a lean release from the comtractors as well when the work is done. You would be amazed at how people frown at them but the banks will require them. Check all the receipts that the contractor runs ask for copys and verify it that you have received it and not another job. Also ask for a carpet alowance along with a tile and appliance allowance. Pick these out yourself and have them at the site to be installed. Most builders will and do use a "builders grade carpet" Also add the vinyl windows instead of the aluminum frame ones. make sure for insulating needs that you have them wrap the exterior framing with the foil and dont use the insulation board. It costs a little more but I would recommend the gypsum board or osb all the way around the building. If th epitch is over 8/12 used the resawn board here as well. mutch sturdier than the osb boards. If you have other qusetions about the process let me know.
  5. #15
    Registered Von Bongo's Avatar
    My Boats:
    1997 Cig Kevlar - powered by Boyd
    Join Date
    Dec 2001
    Iowa - Missouri
    Lenders vary on the amount of equity you need into the project but I would say 10% is going to be minimum and we usually like to see 20% just so we have some room in case of an overrun or unexpected expenses. We also do inspections as properties are built but we have set times such as when framed, rough in.. and so on unless we are concerned about a project. Our biggest concern is with mechanics liens. In missouri a mechanics lien often time takes presidence over our mortgage. In Iowa it only takes presidence if work was done prior to a mortage being put in place. So it depends where you live as to what a lender will focus on.
    A lot of people bid out a house then decide fixtures and so forth just are not what they want so we figure that there will be a 10% overrun on most custom homes and up to 20% on the higher doller stuff approaching a million or more.
    You should check with several lenders to see who has a program that works for both of you.
  6. #16
    Mr. Demeanor
    Going through this ourselves. In some areas it is not possible to general the house yourself using a bank for a construction loan. They will not give you a construction loan unless you are a licesed home builder in the state. This is a new thing so check with your bank.
  7. #17
    Registered 97BossHammer's Avatar
    Join Date
    Mar 2002
    Brandon, MS.
    cool guys, a lot of useful info here so keep it coming. We met with our builder last night and it's basically $85/sq foot ,which is kinda what I was expecting, this is on a 2800sq ft home. I think we can do it but I'm going to check around and see if I can get it cheaper as well.
  8. #18
    My Boats:
    boat less
    Join Date
    Feb 2003
    dude , you need to talk to jeff .......
  9. #19
    Mr. Demeanor
    $85 a square foot, thats close to manufactured home prices up here (about $77). Stick built with nice interior around $120 a square foot and up.
  10. #20
    Registered bikinilover's Avatar
    My Boats:
    Boatless for know
    Join Date
    Oct 2002
    Haslet, Texas
    About $85.00 to $100.00 here in Texas for custom home.
Similar Threads
  1. Advice Needed
    By flash_e in forum Fountain
    Last Post: 06-08-2005, 02:03 PM
  2. Advice Needed
    By c5marine in forum General Boating Discussion
    Last Post: 03-08-2005, 08:29 AM
  3. Carb Advice needed, Please
    By LubeJobs42 in forum General Q & A
    Last Post: 01-20-2005, 01:16 PM
  4. advice needed
    By CHAOS REIGNS in forum General Q & A
    Last Post: 02-28-2003, 01:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
