View Poll Results: silent or loud?
silent
89
37.39%
loud
149
62.61%
Voters: 238. You may not vote on this poll
silent or loud
Old 01-18-2004, 02:10 PM
  #51
Steve_H
i decided to leave it on for those no wake zones and late night rides.
i also like the idea of having a "choice".
Old 01-18-2004, 03:21 PM
  #52
Madcow's Avatar
Originally posted by Ron P
Silent choice won't satisfiy the cops if your in an area where they insist on mufflers.
That may bee true, but if you turn them on as soon as you come off plane you'll probably never get stopped.
Madcow is offline
Old 02-23-2004, 11:01 AM
  #53
Diamond Member #001
C_Spray's Avatar
Keep the Captains Call, just make sure they are the "Normally Open" type. This way, they won't slam shut if something fails, and you can argue that they are not "cut-outs", depending on the laws where you live. ("Cut-outs" are usually defined as a method to bypass the mufflers. If yours are normally open, when you actuate them, the boat gets quieter, and you can make your case.) If your's aren't normally open, Corsa can convert them for you.
C_Spray is offline
Old 02-23-2004, 03:49 PM
  #54
wwwTOPDJcom's Avatar
Default Re: keep em
Originally posted by adrenaln
we use silent choice made by Corsa on all of our boats here, however there are 2 types of silent choice, most guys worry that at speed the flaps will close and choke the motor, however you can have the option of having the flaps open all the time with the actuator closing them only when you want it closed!! those are the ones we use, however alot of people have the other one that is normally closed, using the acutator to hold them open. We dont have alot of areas here to idle, or near restaurants etc, big lakes, big ocean, so we have ours open for the most part, but very nice to be able to run the silent when coming into a harbour etc, but this way if the actuator fails, it stays OPEN not closed, so it wont choke the motor
Full Time Legal Exhaust Systems
QUICK & QUIET™ CORSA’s non-restrictive mufflers and silencers were developed for boats equipped with thru-hull, full-time open exhaust systems. They are the ideal solution for removing the harsh noise while retaining a distinctive rumble and maximum performance. Quick & Quiet™ systems include two patented transom-mounted ASR Silencer Tips and two ASR interior mufflers with a balance tube and are designed to retrofit existing full-time, thru-hull applications.
http://www.corsaperf.com/mbrochure2.htm
I have this brand for sale in the parts section
and you DONT HAVE to wire them open
they are the PERFORMANCE series
Open on start, you have to engage them
to quiet the boat, all the other types
are closed when you start the boat
much better choice for a 500hp and up
wwwTOPDJcom is offline
Old 02-23-2004, 05:43 PM
  #55
Steve_H
i kept them.
dont know if theyre normally open or closed yet.
Old 02-23-2004, 06:15 PM
  #56
WARPAINT's Avatar
Lookin good Steve.When do you make the big road trip to pick her up?
WARPAINT is offline
Old 02-23-2004, 06:27 PM
  #57
Steve_H
leaving march 25.
man o man its been a long wait
hopefully we'll get lots of picks of the trip and post em here.
Old 02-23-2004, 06:49 PM
  #58
formula31's Avatar
They do limit how far you can go with the engine due to the short risers and early water discharge. BUT, they are the greatest when you are trying to sneak in or out of anyplace in the wee hrs. Or, getting by the police without drawing too much attention.
formula31 is offline
Old 02-23-2004, 08:18 PM
  #59
marinetrans's Avatar
Spice up some sailboater's lives w/ some Stainless Marine Gen3 5". Its their favorite exhaust.
marinetrans is offline
Old 02-23-2004, 11:46 PM
  #60
SOX
Semper Fi
SOX's Avatar
I always like options. Keep 'em!
SOX is offline
Quick Reply: silent or loud
