Houston Prop your web link in the bottom of your post does NOT work.
Do you have a running website? If so can I get the link? Looking at getting my 28 b1's tweaked for the spring. stock 502's on a 28'Advantage Cat Touching the revs regularly, few times have not been able to hit the revs. Mostly full weight and rougher waters. I feel I need more stern lift. Also looking at buying a set of Hydros just for this reason, but need to test first. Do you offer prop swaps for testing? been told around a 27-30 hydro needed. What I would like to do is have a set of lake props, ones for improved planning and not so worried about top end. Adn then a set of props, maybe the Hydros, for top speed. Thanks |
Darin,
You are right on all counts. It would have taken alot to clean the one up and make a matching pair. I did not think of that. Sure glad they were brand new when I bought them. :rolleyes: I am very happy with the way they are. I rather have the meat on them for use than make them picture perfect. Thanks again for the work and the repair certificate. Jerry |
I love HoustonProp they rule !!!!!!!!!!!!!!!!!!!!!!!!!!
PS, I have Three Props I need checked out. I don't even have to worry about shipping. |
Originally posted by HOUSTONPROP ROGER 1 /THANK YOU YOU JUST RECIEVED 25% OFF YOUR NEXT REPAIR OR LAB FINISH WORK ,JUST PRINT THIS AND INCLUDE WITH PROP WHEN THE TIME COMES. |
TOMTBONE/
1 Attachment(s)
stop by when you can,bring all three and we will cutyou a deal,
Thanks, DARIN ROGER1 ThankYou!!!!!!!!!!!!!!:cool: we are still swamped in props can't complain about that :D Thank You all so much for your support! |
:D :D :D :D ;)
