If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 7 of 7
  1. #1
    My Boats:
    25' Checkmate Convincor, 19 Checkmate Convincor, 23 Crownline, a Sea Doo, a 12' sailboat, and two kayaks!!
    Join Date
    Sep 2002
    King george, Virginia/Potomac River
    Lets hear your best MacGuyver boat story
    It's winter (shut up bottom and left coasts) and we're all bored as hell. Tell us about your best quick fix, duct tape, shoe string to get back to the dock story.
    Here's mine;
    Years ago in my old bow rider we were headed back to the dock after staying real late at Jamaica Joe's Crabhouse. They had a band playing that sounded real good which was rare. It was about 2am and we were running about 35-40mph and I was getting close to the very narrow channel leading to the marina I launched from. I grabbed the throttle (horizontal mounted shifter/throttle) to slow down......OH was frozen in place. I pulled on it real hard and it would not move. I tried not to panic but unlit channel markers were approaching real fast that I knew were there but had not seen yet. So i just grabbed the key and shut off the motor. Now we were adrift at 2am with the the boat in gear and at part throttle. I looked under the gunwale with a flashlight but could not see anything wrong. Opened the engine hatch but nothing wrong there either. Tried to restart the motor but the neutral switch prevented that. Hummmm how do we get in????? I pulled out the tool box and disconnected the shifter cable at the transom, and disconnected the throttle at the carb. Took a long screwdriver and jumped across the 2 starter terminals to fire the engine. Grabbed the throw cushion to sit on and told my buddy to steer. I sat on the deck and put it into gear and worked the throttle at the carb. If the APBA could have seen 19' bow rider now had a driver and a throttleman!! Too bad it was dark and late, it probably look funny while we docked.
    The next day I checked out the problem. Turns out the one of the four mounting screws for the shifter/throttle assembly had backed out. These screws are behind the round base part of the throttle arm. When it backed out, it backed out into and perfect size hole on the backside of the throttle arm.
  2. #2
    Registered HiPerf2000's Avatar
    My Boats:
    Join Date
    Oct 2000
    had a blower belt go once....i made a new and improved one out of Duct Tape. Got me back in.
  3. #3
    Were doomed! Charter Member Wally's Avatar
    My Boats:
    Chris Craft Stinger 222
    Join Date
    Oct 2000
    Chicago, IL
    Oh man.....with all my idiot friends where do i begin!!!
    One of the most memorable events i had was jetskiing one year a while back. We just got out past the break wall and gave it gas and was just about up ontop of the water when BLAH..the motor sputtered and died.....WTF??? Crank and nothing.....waves are crashing on me and rolling the ski when i cant get controll of it.....i finnaly flag down another jetskiier on a waverunner and he tows me in......during the tow the ski floods and sinks!!! all you see is about 2' of the nose in front where it was filled with foam!! So i get back to the beach and start to see what went wrong. Come to find that one of the two bolts holding the carb inplace is snapped clean off and flush with the intake manifold! i dont have any real tools at hand other then a small fix-it tool box) So i sit there on the beach and tell my buddies to go ahead with the rest of the sense in calling it a day for everyone. While i'm sitting there getting a Tan i'm thinking on how i can fix this.....then i get a bright over to the marina and see if they have any silicone....yes they do!!! run back to the beach and take the carb off the intake....clean off the mating surfaces....put a thin coat of silicone on the intake and on bottom of carb....let stand for 15min to get tacky.....install carb back on intake and crank down the one bolt. Zip-tie the other side of the carb to the intake and wahla!! I jetski the rest of the day like nothing ever happened and was gonna use it the next day the same way but friends wouldnt let me!
  4. #4
    Registered robyw1's Avatar
    My Boats:
    1998 Wellcraft 22' Scarab
    Join Date
    Jul 2003
    Spring, TX
    Well my old bowrider was T-Boned by a Jet-ski going about 50-MPH. The idiot didn't realize that you have to throttle it to make it steer. It caused about 7500 in damage andwe thought it might sink. I didn't attempt to fix it but we made everyone put on vest and sit on the good side of the boat so the damaged side would be up out of the water. We almost sank it back at the marina waiting to put it on the trailer.
  5. #5
    The Illustrious One Charter Member sean stinson's Avatar
    My Boats:
    Back on the dock!!!!!!!
    Join Date
    Oct 2000
    Internationally Famous
    I used a pair of fish net stockings for a power steering belt one time.....
    Dying,....Is the day worth living for!!!!!!
  6. #6
    Platinum Member Platinum Member Tinkerer's Avatar
    My Boats:
    2001 Daytona 26, 1992 SCARAB 34, 1989 25 Checkmate Convincer, 1977 Glastron Carlson CVX 18
    Join Date
    Jan 2002
    ALTO, MI
    First time out in the spring.
    get to the boat ramp and fire up the port engine and then reach for the starboard key. Did I say that my boat is a two key boat. The other key was at home.
    I hot wired one of the engines so that the run wire was always energized but if you pulled the lanyard it would kill it. So the process for the day was install the lanyard then use the one key to start that motor then remove the key ( the engine stays running ) insert the key in the other motor and start it normally.
    Then there is the time I blew the shift cable on one of the motors on the second day of a 5 day port hopping trip.
    Had reverse but no forward on one motor.
    swapped the props and then drove the boat back to the trailer and replaced the cable. ( shiffters were in reverse )
    then ran at a much higher cruise speed back to the next port on the list.
    Hey even if it ain't broke it's still fun to tinker with it.
  7. #7
    My Boats:
    85 Formula 302
    Join Date
    Aug 2001
    Indy, St. Louis, LOTO
    So, you went bare-legged? Didn't that wreck the look of your outfit?
Similar Threads
  1. Lets Hear Em
    By BY U BOY in forum General Boating Discussion
    Last Post: 11-05-2006, 08:15 PM
  2. Lets hear Your Best /worst Gas station story!
    By blownincome in forum General Boating Discussion
    Last Post: 02-09-2005, 07:32 PM
  3. O.k. Lets hear it.....
    By Need-the-Speed in forum General Boating Discussion
    Last Post: 11-02-2004, 12:15 PM
  4. Lets Hear it for Greg Biffle
    By Dock Holiday in forum General Boating Discussion
    Last Post: 11-14-2002, 04:12 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
