Ford F-150 super screw HITCH clarification...
Look for the TITAN receiver hitches. Yes the split weight is without/with the distribution arms. The true TITAN hitches are 2.5x2.5 slots there is an adaptor that can be purchased to reduce so you can use a 2" sleeve drop. Also check the max weight of the ball as well some have lower ratings than others, will be stamped on top of the ball. Also the shanks will be different in diameter as well.
Don't forget that the receiver inserts come in different weight ratings. The one I use with my Class V hitch is solid steel, not the hollow 2x2" tubing. Steve
Charter Member #232
Originally posted by Baja Daze
Chris.
Important!!! The factory hitch on Ford trucks is only a class 3(500/5000). Despite the fact that there's a "V" on the hitch. The "V" is some kind of part number or stock stamp, not the class rating.
This has come up before.
http://www.offshoreonly.com/forums/s...ck+Class+hitch
Chris.
Jon
Put your best foot forward!
BillR
2
10-24-2007 08:36 AM
Chris288
5
01-19-2005 02:58 PM
