If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    AT Cult Member #3 VIP Member R Addiction's Avatar
    My Boats:
    '99 Active Thunder Tantrum
    Join Date
    Oct 2000
    Originally posted by Airpacker
    AMEN to that Pass me another intake manifold please
    LMAO!!! Doing one as we speak$$$$$$$$$$
  2. #22
    Registered HyperBaja's Avatar
    My Boats:
    1990 Baja 190 DSR
    Join Date
    Sep 2002
    Lewis Center, Ohio
    For some reason ours hasnt broken yet!
  3. #23
    Ike is offline
    Charter Member#93 Charter Member Ike's Avatar
    My Boats:
    1989 41ft Apache Indian Outlaw
    Join Date
    Oct 2000
    The Burbs
    That's funny
  4. #24
    Registered LaserLTV's Avatar
    My Boats:
    Laser LTV
    Join Date
    May 2002
    Atlanta, GA
    Check the fuses
    On the LT1 Camaros there is a fuse for the ignition system. Check to see if there is (or was at any time) coolant coming out of the weep hole on the bottom of the water pump. If there are any marks on the bottom of the water pump you can be fairly sure that the trigger in the Opti-Spark went bad. The 93-94 LT1s were real bad about the water pump leaking and getting the Opti-Spark wet. In 95 they changed over to a vented Opti-Spark to "help" correct this problem. Have you scanned the ECM to see if there are any codes stored in it. If it wont start it will usually throw a LOW RESOLUTION FAILURE code, but even if there isn't a code stored it can still be bad. There are two triggers in the Opti-Spark, a low resolution and a high resolution. The HIGH RES code usually wont stop the car from running. You'll also want to check and see if the coil has a signal going into it, this can be done with a test light on the small wires going into the coil. When you probe the +12V side of the coil with the wire on the test light grounded the test light should light up. When you probe the other wire (in the same plug) with the wire on the test light connected to +12V and crank the engine it should pulse. If it doesn't pulse then it would point to either the ignition module or Opti Spark. If you have any questions feel free to email me Jeff-Thunder Performance
  5. #25
    Registered mikev's Avatar
    My Boats:
    1988 Donzi Regazza
    Join Date
    Sep 2001
    Cumming, GA.
Similar Threads
  1. Pinks: Firebird vs import
    By CBR in forum Trucks, Trailers and Transportation
    Last Post: 06-21-2006, 09:28 PM
  2. OT: high intensity headlights for firebird
    By CBR in forum General Boating Discussion
    Last Post: 12-01-2002, 01:02 AM
  3. OT; need help with LT1 motor
    By Hot Boat in forum General Boating Discussion
    Last Post: 09-25-2002, 08:47 PM
  4. today's the last day of camaro/firebird production
    By Advantage_Rob in forum General Boating Discussion
    Last Post: 08-30-2002, 08:36 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
