If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    i e-mailed for a brochure and pricing....and if import fees apply..etc...waiting to hear back....but my biggest concern is where to get high grade fuel I think they use filtered light grade kerosene with an additive....and along with air cooling....they don't need "oil" changes...they must cost a kings randsom...
  2. #12
    ...the best part is you can use Bravo's!!
  3. #13
    Registered Shane's Avatar
    My Boats:
    2009 FORMULA 292
    Join Date
    Oct 2000
    Lake George, NY it's not called "Queen of American Lakes" for nothin'!
    How many RPM's do they idle at? Run at?
  4. #14
    .....a company rep also fitted a pair to his searay 39' which was an older boat.....and jackshafts and he said top speed is around 45mph...and about the same fuel efficiency as a pair of 6.2 liter engines...
    ....these turbines put out 400HP but 600 ft lbs of torque so they perform more like 600hp engines ....and weigh 158lbs....turbines are fascinating engines...
    ....they also have "lease programs" where they own the engines...and you pay then for hours of usage per year...he was surprised that they haven't been marketed in the usa...lot of road construction equiptment in eurpoe uses of these 158lb engines is plenty for a conventional sized cement truck fully loaded....with a rear piston engine to "spin" the cement mix...
    turbines will be the future of performance boating I think when they mass produce these....and they do spin the props really fast so you need a 40% bigger pitch than a comparable pitched big block with the same horse...and expect to see roostertail's baby!
  5. #15
    Platinum Member Charter Member
    My Boats:
    Join Date
    Jan 2001
    so. WI
    Most turbo-shaft engines used in the marine environment have had their fuel controllers modified to use diesel fuel.
    That little fella looks like an Allison used in the Bell 206 Jet Ranger- although good in the weight department, they lack the torque of the larger turbo-shafts that have been marinized i.e. the Lycoming LTS-101 (650 shp) and the T-53 thru T-55's that can be modified for up to 4000 shp (unlimited hydros are an example).
    The LTS-101 is a comparable to a Merc 800SC in fuel burn, but has more available instantaneous torque. These were used in the Hueys circa Vietnam era. The T series Lycs are used in the twin-rotor Chinook.
    If I had the bucks, I would much rather have a set of turbo-shafts than deal with the short life of a supercharged piston engine, which simply is a bunch of thrashing parts looking to beat their way out. Although turbines seem to be some kind of voodoo science, they are extremely simple to maintain. If you can change oil and plugs on a piston engine, you can do ALL the necessary maintenance on a turbine. If you boat 100 hours a year, the engines will still be running fine when you're taking a dirt nap.
  6. #16
    GLH is offline
    Platinum Member Platinum Member GLH's Avatar
    My Boats:
    Join Date
    Dec 2002
    Burlington, VT
    Originally posted by LPA2106
    ...looks tempting eh?
    make sure you get your insurance quote before sending out the P.O.
Similar Threads
  1. How much HP with this Combo?
    By Pat McPherson in forum General Q & A
    Last Post: 12-08-2006, 09:00 PM
  2. 29 w/ 377 scorpions, good combo or bad???
    By rslick in forum Fountain
    Last Post: 01-12-2006, 07:00 PM
  3. What do you think of this combo
    By PatriYacht in forum General Q & A
    Last Post: 08-08-2003, 10:08 PM
  4. combo
    By speedmaster3 in forum General Q & A
    Last Post: 10-02-2002, 12:42 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
