I have a strange vibration when towing
had a problem myself recently.
http://www.offshoreonly.com/forums/s...highlight=rear
yours sounds different though.
a u joint would do it when releasing the pedal after acelerating like the neutral zone. chcke the lug nuts on the trailer tires, check and make sure the trailer hubs are tight enough with a little rolling friction on them.
on-off vibrations are usually high RPM like engine, flywheel, torque converter, However if he has low gearing in that Bronco then I would check drive shaft alignment. If it were a U-Joint it would be vibrating with or without a boat. If the boat is putting a lot of tounge weight it could be pushing the rear suspension down far enough for your driveshaft to be out of proper alignment. It sounds dumb but it is VERY important. Especially in raised off-roaders. I had a driveshaft vibration so bad once it broke the bellhousing on my Turbo 350 and turned whole transmission up-side-down.
Roby
Roby
Also if you do replace U-Joints BE SURE that if you get the ones with the grease fitting that you position that section of the u-joint with the fitting to be compressed and not spread. This is the MOST COMMON mistake in installing u-joints and it is VERY IMPORTANT to keep them from failing. If you don't understand what I mean e-mail me and I will explain this in full detail.
Roby
[email protected]
Roby
[email protected]
Bearing buddies can be a pain. If they are cocked back and forth while installing or removing, the housing gets distorted and loses it's fit, and comes off. They have to be installed /removed as straight on as possible.
Charter Member #94
BR,
You have two different problems here...
1. fix the bearing that is about to fail. Yes, the one that has spit out the bearing buddy, twice.
2. You have a lock up convertor. It's called torque convertor clutch shudder. Is really noticable with vehicles with automatic overdrive transmissions that tow in overdrive.
Abby-someone
Abby-someone
Charter Member #737
You are need to replace the U joints even if that is not your problem. They are past due.
Replace the bearing buddies and repack the bearing to save any problems this summer.
You should not tow in overdrive with your small truck.
Charter Member #94
Abby-someone
Abby-someone
