transom soot- cleaning
Old 04-05-2004, 12:00 AM
Default transom soot- cleaning
Whats the best cleaner to use to get rid of transom soot?
poolshrk is offline
Old 04-05-2004, 05:59 AM
mama tryed's Avatar
Elbow Grease and quit running Premium!! If all else fail's,, I use Acetone!!-{spell Check}
mama tryed is offline
Old 04-05-2004, 06:03 AM
Charter Member#157
MnFastBoat's Avatar
stop running premium??
Does Premium gas actually give more Soot??
I would think it would burn cleaner
Maybe that is why mine is so dirty, because all I run is 90+
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-05-2004, 06:23 AM
Chris's Avatar
Try Simple Green, the stuff works GREAT on transom soot!!!
Chris is offline
Old 04-05-2004, 06:30 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Lowest octane you can run without pinging and Simple Green. Also, assuming you have an EFI, as the season warms up a bit, your soot will decrease.
Sydwayz is offline
Raypanic's Avatar
!Black streak remover! Starbrite. Works great
Ray
Raypanic is offline
Old 04-05-2004, 06:37 AM
Canada Jeff's Avatar
If you keep the transom waxed, it helpes too.
Canada Jeff is offline
Old 04-05-2004, 06:51 AM
Macklin's Avatar
Premium will make the computer / engine run rich which increase soot.
Keeping the transom waxed definitely makes clean up much easier. For the really tough soot go to West Marine and get a bottle of Black Streak Remover that Ray mentioned.
Macklin is offline
Old 04-05-2004, 07:26 AM
throttleup's Avatar
After you remove the "soot". I highly recommend that you apply Frenzy. This will aid in removal the next time around. You will literally just have to wipe it off. I have seen this with some of my race clients.
Julie
throttleup is offline
Old 04-05-2004, 08:17 AM
BajaRunner's Avatar
formula 505 from home depot, works great
BajaRunner is offline
Quick Reply: transom soot- cleaning
