Kevin's
If my memory any good, I think it was 3 to 4 blocks, and 5 to 6 bal jobs. My balance jobs are easy to identify because I only use 1" or 7/8" drill bits and I try to keep the amount of lighting holes to a minimum, usually two!!
KR |
Re: Kevin's
Originally posted by kevinr If my memory any good, I think it was 3 to 4 blocks, and 5 to 6 bal jobs. My balance jobs are easy to identify because I only use 1" or 7/8" drill bits and I try to keep the amount of lighting holes to a minimum, usually two!! KR Kevin good luck :D Rob |
1 Attachment(s)
Here are some shop pics
1 Attachment(s)
shop pics
1 Attachment(s)
balancer
1 Attachment(s)
dyno
What are you using to cut the seat in the heads??I see the valve grinder
Strip Poker , I use multi angle Hi perf carbide live pilot cuters in my DCM guide & seat Machine. Every now and then touch off seats with stones. Especially if cutter chatters or if I dont like the finish...try to keep seat width's narrow.. KR
Kevinr.
your shop looks awesome and you seem to be an up and up guy, but from someone who got screwed by Todd and have been tracking him for over a year. talked to many guys that have been f**ked by him for allot more then me. I still have the motor from him that I paid 9,000.00 for and had to just put 3200.00 to even think think about selling it. which in that figure I saved 1200. in labor because I assembled it my self. Plus Dyno 1 when it came out of the crate and looked like a Junkyard motor and Dyno 2 to make sure everything was right when it was back together. additional cost 900.00. now the bottom end is right, merlin 111 block, cyptinight crank now needs a good set of heads. my 575 hp bulldog still only produced 509 @ 5000rpms. So If I was you I would not do any business with Todd and put a firewall up against your name and his you are just enabling him to continue to scr*w people and he will bring down your name. Read the treads its all there. he is on his way To court we have been asked to testify against him. will he bring you in and say you did this work he had no idea. If I was you watch your back when it comes to Todd.He is smooth. |
HawkPower
Todd is out of business , I purchased remaining inventory and name, read thread new ownership Hawk Power KR
