View Poll Results: What size fuel tank to size boat?
25-30' - 50-75 gal
22
10.33%
25-30' - 76-100 gal
36
16.90%
25-30' - 100-125 gal
30
14.08%
25-30' - 151 plus gal
14
6.57%
31-35' - 100-125 gal
4
1.88%
31-35' - 126-150 gal
5
2.35%
31-35' - 151-175 gal
19
8.92%
31-35' - 175 plus gal
22
10.33%
36-40' - <200 gal
10
4.69%
36-40' - 200-250 gal
28
13.15%
36-40' - >250 gal
23
10.80%
Voters: 213. You may not vote on this poll
#31
107gal in my little 242 single bbc
#33
I think the minimum would be 100 gal for anything over 23ft. Some of these 40+ with under 200gal, how do you do that? You need to figure 1 mpg average. The 200 gals I had in the Donzi was perfect for most trips, I rarely filled it though since 200 gal at about 5lbs per gal means a lot of dead weigh and when I trailered it to the UP I would time it so I went with no fuel and came home with no fuel, that could save almost 1000 lbs of weight.
#35
Charter Member #319
Originally posted by craig223
Two 94 gallon tanks in a 31 footer.
That's 188 gallons for those of you that can't add!!
That should be enough to get you up here and back
#36
Originally posted by PhantomChaos
135 in a 312 Formula
200 in a 382 Formula
390 in 48 Sunseeker
390 in 48 Sunseeker
I think you have enough toys already!!!
I have Four 55 gallon tanks in a 33'
#40
Re: What size fuel tank to size boat?
baja 272,97 gallons if completely empty,but i don't lean on boost on last 15 gallons,occasionally will drop fuel presure if you do,Smitty
