Nor-Tech 4300 Supercat 1st test run
IMPRESSIVE great speed for a wide body cat, boat looks alot larger in the water than the 36, Terry, what is the weight difference between the two.
I wonder what it would do with some TMP 1500's
Thats The Right Size For BIG Speeds
Nice piece, 1100hp on pump gas and pushing a wide beam 140+ when light.......If it stays settled at those speeds I say mission accomplished. None of them need to go faster than that (or that fast), at that level nobody ever "tests" you
BTW whats the displacement on the engines and at what boost and rpm are they making the HP ?
Sorry for all the questions but I'm really impressed by your motor program.
JD
JD
Member #154
Originally posted by Troutly
Very good looking lines to that boat.......I bet it will look stunning when painted
