What is this tool called??????? >
Old 04-22-2004, 08:36 AM
Question What is this tool called???????
I want to buy the tool that you see the guys on American Chopper use. It is the one they use to smooth and polish metal. It is neumatic and you can use different wheels. I went to Home Depot last night they didn't have it. Does anyone know what it is called and where I can buy one and the various attachments?
Shane is offline
Old 04-22-2004, 08:38 AM
MitchStellin's Avatar
It may be a die grinder with attachments, sounds like the head may be the piece you need and use a drill or a high speed grinder to spin it fast enough. You need a ton of air to run these things.
MitchStellin is offline
Old 04-22-2004, 09:03 AM
Chris288's Avatar
these maybe ????
http://www.northerntool.com/webapp/w...categoryId=145
Chris288 is offline
Old 04-22-2004, 09:12 AM
Go down a little ways I believe it is called a high speed air sander.
http://www.eshop.msn.com/marketplace...Id=2555&page=4
Shane is offline
Old 04-22-2004, 09:14 AM
Official OSO boat whore
You do need a bunch of air to run it continuously. I have a 5hp 2 stage compressor and it just barely keeps up. They are readily available, especially in the cheap Chinese version. If you want a tool that will last, buy a good name brand one from Grainger or other commercial tool house.
The alternate would be to buy a 4" electric grinder. You can put slightly larger cut off wheels in it and it will run all day. They cost about the same as a good quality cut off wheel, or about twice the cost of a Chinese one.
McMaster Carr has a pretty good selection of them. Search using "air die grinder". There are two types. One will have a shaft that will allow you to mount a wheel with a hole. The other will have a collet to allow you to mount stones and burrs with a shaft.
Cord is offline
Old 04-22-2004, 09:15 AM
No, this...
http://www.northerntool.com/webapp/w...egoryId=765392
Remember, Norther carries the cheap Chinese version.
Cord is offline
Old 04-22-2004, 10:08 AM
Chris288's Avatar
Yup northern does carry some cheapo crap,, but they also carry I.R. which is not..
so you got these ::http://www.northerntool.com/webapp/w...egoryId=765392
or these:: http://www.northerntool.com/webapp/w...categoryId=145
Chris288 is offline
Old 04-22-2004, 10:16 AM
IR seems to be spotty. I have that kit you linked to. I don't think IR built it. I'm pretty sure it's a standard Chinese POS with their lable on it. I don't have more than 5-10 hours on the grinder and the gears are feeling very notchy. The body has the same blank circle all the Chinese ones have. The funny thing is that I also have the IR orbital sander you linked to. That is a very nice sander. Good power. Smooth. Good throttle control. Very quiet.
Cord is offline
Old 04-22-2004, 12:11 PM
When you buy air tools look at the "CFM " rating .
If one says it uses 15 cfm and one says it uses 40 cfm , then the one with 15 will do the same job with less air .
BUT , sometimes it takes more air to do more work . It depends on how hard you lean on it . Kind of like horse power and fuel economy , ya know ??
boot is offline
Old 04-22-2004, 02:05 PM
Scott B's Avatar
If it uses less air, it is doing less work. Just like the formula for speed ($peed co$t$ money, how fa$t do you want to go) performance in air tools is related to air consumption. Yes, there are inefficent tools out there, usually the cheaper stuff, but as a rule of thumb buy the tool that uses a skoosh more air, it will have more hp, and work better for you.
As far as compressors, 5 HP is not always 5 HP. IR for example, has 5 hp units that put out 111 - 18 CFM, all at varying pressures. Pressure is not what does the work in air tools as long as you are in the tools operating range, volume is. So, go for the most volume closest to the operating pressure of your tools (most are 90 PSI) and then go a step bigger for those times you want to run a small blaster or whatever...
Last but not least, IR (and most other well known brands) has consumer, automotive, and industrial units. IMO, buy at least the automotive units, but if your working them hard, buy the industrial's. We sell all of them, and the industrials are one time sales, with a few maintenance parts down the road. The others keep my tool repair guys employed....
Scott B is offline
Quick Reply: What is this tool called???????
