If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Charter Member # 1215
    My Boats:
    Join Date
    Feb 2001
    hewlett NY
    Adding Oil Heaters
    I was at a Dinner the other night, where I had met the owner of a NASCAR TEAM, while discussing engines he had suggested to add oil heaters which would add a tremendous amount of engine life (preventive maintance) , curious if anyone has done this setup with 500EFI.
  2. #2
    Registered Reed Jensen's Avatar
    Join Date
    Dec 2003
    Los Angeles California
    I've never seen it installed on a boat.... the way they work in a nascar is they are plugged into a wall outlet before they start the car... the oil pan has a heater inside.... the oil is preheated to 200 degrees so that it flows better upon start-up.
  3. #3
    Rob VIP Member Strip Poker 388's Avatar
    My Boats:
    Hustler 388
    Join Date
    Aug 2001
    I don't think you need it . Most of them use it on there dry sump tanks . I don't use them on any of my race cars or my blower motors and I have never had a bearing problem .
    If you where up north cold cranking it might be a would be easier to crank.
    I do always wait till I see the oil temp gage move before calling on it. The Hustler has a Oil thermostats . It takes about 10 min to get some oil temp
    Boost makes up for Cubic Inchs
Similar Threads
  1. PICS...Adding Oil Temp Gauge...A Few Questions
    By allenk4 in forum General Q & A
    Last Post: 08-08-2007, 01:59 PM
  2. Replies: 2
    Last Post: 04-17-2006, 07:15 AM
  3. Adding oil temp and water pressure gauges
    By boatinbill in forum General Q & A
    Last Post: 03-06-2005, 08:27 PM
  4. Thinking of adding an oil stat...
    By dyno in forum General Q & A
    Last Post: 06-08-2004, 07:58 AM
  5. adding oil
    By scervin in forum General Q & A
    Last Post: 07-17-2003, 08:44 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
