500efi owners Heads up!!
Registered User
1 Post
Yes I replaced the gaskets also along with, spark plugs, distributor cap, and impeller. I actually used the replacement springs from merc, kind of wishing I had used Isky now??
Also I didn't think I had lost any power but I had, once I put back in the water I did notice an increase in power, not more speed but got to max rpm much faster.
If you have the carb version you need to change them at 150-200hrs I did learn that during my research, actually the carb springs are suppose to wear out much faster, I think they used a different spring.
Good Luck
WILL
Good Luck
WILL
This is the most talked about engine for just this reason!
I have an EFI version, and read every post about these blue motors for the past three years.
Long and short of it, 200 hours is a good bench mark for valve replacment. Period!
Compresion test won't tell you dick!
leak down test won't tell you dick!
Visual check is the closest you can go, without buying a spring preasure tester.
If your at 200 hours, change your springs!
I'm sure I'm going to hear a few stories of 300 and even 400 hours engines running fine, I don't care! Down time to me is important. Schit we only get 4 months up here. If you can't aford to do the valves, you shouldn't own the boat!
