Powder coated props
So if they are test props I would "assume" that the powdercoating does not change the performance of the prop relative to the polished finish. There are a couple of the designated "test" props here:
http://www.mrboats.com/specials.asp?cat=ACCESSORY
I think that they look cool. Do they come from merc in any other colors?
KiloKat
Originally posted by PokerRunGunT/S
I am trying the Hering 6 blades (27's) and a new set of labbed 28 Mercs. I currently run Labbed 30's but I am short on my RPM's.
Charter Mod
Originally posted by KiloKat
You will need 29 Herings to compare top speed against 28 Mercs. The six blades will give you added acceleration but will also give you more bow/stern lift depending on which direction you are turning them.
So I would actually need a bigger size in the 6's over the 4 blade Merc?
KiloKat
No, it has nothing to do with the number of blades. Mercury's advertised pitch has always been one lower than the standard used by Hering, Rolla, etc.
Charter Mod
Powerguy: Sorry, wasn't trying to hijack your thread.
KiloKat
I definately prefer the Herings for most of the conditions we run in but also carry Mercury & Rollas for special situations.
Not necessarily true. Actually depends on diameter, blade thickness and boat setup.
Originally posted by audacity
dude if u can only turn a merc 28 4...there is NO way in hell your going to spin a 29 6 blade hering.
