NJ Registration #'s on hull
Location: Pennington, NJ/Delaware river/Upper Chesapeake bay
FatDaddy,
Contact Bill Nemec in Flemington at 908-782-3175. He's done many jobs for me, both paint and vinyl. Great at color matching and reasonable too. Tell him Dave the toolman sent you!
You can get trick lettering too....not just the TOO OLD style basic, black block letters that your mom and dad used to have.
I have my numbers attached to the side of race fairing that rises from the deck, right above the walk around.
Looks nicer than on the hull, easier for coppers to read also.
Toxic FORMULA
Originally posted by Formula Outlaw
No offense whatsoever to all the fine people who live in New Jersy, but with regards to the politics and the manner in which their State Police operate, as far as I'm concerned you could encircle the entire state (except for the Devils) with D-9 Cat dozers, drop the blades, and meet in the middle.
Reg.#
fat daddy,
I documented my 357 in ohio. Coast guard rules
state you don't need to display reg. # if you put the
name of your boat an your home port in 3in.
letters on the transom plus the serial number they will
send you will be placed in the engine room below the water line letters 3in. tall epoxyed to the inner hull.
boatus will have them made for you for I think $60.00.
In ohio the state sticker is applied to your side windows.
I don't think that even the state of new jersey can over
ride the us coast guard & the dept. of home land security, plus if your boat gets ripped off the federal
gov. goes after it.
gov. goes after it.
Diamond Member #001
Re: Reg.#
Originally posted by bobbarker
....Coast guard rules state you don't need to display reg. # if you put the name of your boat an your home port in 3in. letters on the transom...
... plus the serial number they will send you will be placed in the engine room below the water line letters 3in. tall epoxyed to the inner hull....
Here's the USCG text:
"HOW DO I MARK MY VESSEL?
The official number assigned to documented vessels, preceded of the abbreviation "NO." must be marked in block-type Arabic numerals at least three inches high on some clearly visible interior structural part of the hull. The number must be permanently affixed so that alteration, removal, or replacement would be obvious and cause some scarring or damage to the surrounding hull area.
The name and hailing port of a recreational vessel must be marked together on some clearly visible exterior part of the hull. The vessel name of a commercial vessel must also be marked on the port and starboard bow and the vessel name and the hailing port must also be marked on the stern. All markings may be made by any means and materials that result in durable markings and must be at least four inches in height, made in clearly legible letters of the Latin alphabet or Arabic or Roman numerals. The "hailing port" must include both a place and a State, Territory, or possession of in the United States. The state may be abbreviated."
Back to NJ....
Ok, here's an update. According to the U.S.C.G. website the state can not require you to display state registration numbers if the boat is documented and current. You still are required to display the state-issued registration sticker. If it's not documented you're hosed.
http://www.uscg.mil/hq/g-m/vdoc/faq.htm#15.
