Drill pump safe for fuel... >
Old 05-03-2004, 08:55 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Default Drill pump safe for fuel...
I want to drain the rest of the tank on the Sonic. Anyone know where I can pick up a relatively inexpensive but worthwhile pump that is safe for pumping fuel?
AtDhVaAnNkCsE !
Sydwayz is offline
Old 05-03-2004, 08:58 AM
OldSchool's Avatar
Default Re: Drill pump safe for fuel...
Why?
OldSchool is offline
Old 05-03-2004, 09:00 AM
The drill pump itself is OK for fuel. It's the sparks generated by the drill you have to worry about. You dont want to make a flame thrower!
Gary Anderson is offline
Old 05-03-2004, 09:01 AM
BTW, I've got a $30 carter electric fuel pump for jobs like that. Most auto parts stores will have them.
Old 05-03-2004, 09:48 AM
Forum Regulator
Sydwayz's Avatar
Default Re: Re: Drill pump safe for fuel...
Originally posted by craig223
Why?
For transport... to lighten the load a bit.
Thanks Gary.
Sydwayz is offline
Old 05-03-2004, 09:55 AM
Official OSO boat whore
I have used the drill pumps successfully. They do take a while though.
Cord is offline
Old 05-03-2004, 10:16 AM
JUSTONCE's Avatar
I wouldn't worry about it.
JUSTONCE is offline
Old 05-03-2004, 10:28 AM
Forum Regulator
Sydwayz's Avatar
ROFLMAO!
Sydwayz is offline
Old 05-03-2004, 10:31 AM
Mr. Demeanor
I bought one of those siphon tubes that has a check ball in it. You shake the tube ( ya, it looks like your wackin it) it it gets the siphon started. I had to drain 100 gallons of old fuel when my boat was in extended storage. I had all the neighbors show up with their lawn mower gas cans and they were all appreciative. Its a good size hose and works well. Nice to have around and you don't need an outlet if you ever need a few gallons out of the tank for your own mower. I pull the sending unit and go straight into the tank.
Old 05-03-2004, 10:34 AM
Mr. Demeanor
By the way, at 6 pounds a gallon is it really worth the effort. What are you towing with and how much?
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
jdub
7
03-26-2007 05:06 PM
Quick Reply: Drill pump safe for fuel...
