Pachanga blew up
Blew Motor?
Probably jumped timing and maybe even sucked some water into one of the cylinders. Pull all the plugs out and see if you can turn over the engine. Good luck
Location: On the back of a chicks M3..If you're gonna ride my ass at least pull my hair!!
I had a gimble bearing go bad and it grabbed the yokeshaft.
Now beleive it or not the motor wanted to start but wouldn't turn over fast enought to light.
I put both batteries on it and literally stripped the yoke splines........oh she started right up then.
It did this all of a sudden....no warning.
Motor's that jump time miss fire......motors with water show signs in dipstick.
Motor's that are blown have big holes to show you.
Originally posted by RonS
TITS WHEELS AND PROPELLERS, THERE ALL GOING TO GIVE YOU TROUBLE SOONER OR LATER, MIGHT AS WELL GET USED TO IT
THANKS, GOD!!!
Pulled the drive off and it cranks, drives locked up bigger'n chit.
Oh man, am I relieved. A drive rebuild I can afford, had the motor been gone I'd a been pontooning all summer.
Toxic FORMULA
Originally posted by KH0302
Pulled the drive off and it cranks, drives locked up bigger'n chit.:
(I've seen uppers , lowers and universals go )
