If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
  1. #41
    Join Date
    Jan 2004
    San Diego, California
    Re: Merc. dropping 3 engines.. bye bye 500 EFI !!
    Were getting 556 HP with a stock block 496HO with new aluminum heads and manifold and cam change. This is with the Merc stock ECM programming. This just about says what the future of the HP525efi will be. More horsepower, more torque and a helluva lot less money! I am Sure Mercury racing will come up with something like a 540 cu.inch motor with more compression and hump out about 600 to 625 reliable horsepower. The real question is when is someone going to build a 600ft/lb torque capable outdrive that does not require a second mortgage to purchase???
  2. #42
    Gold Member Gold Member Hydrocruiser's Avatar
    Join Date
    May 2004
    Arrow Re: Merc. dropping 3 engines.. bye bye 500 EFI !!
    Well Mercury offered a choice of the XR or #6 on the HP 575 SCI 550 HP motor. The good news about the dry sump in the #6 obviously is that it requires less oil in the sump reduces friction, adding 50 to 80 prop-shaft horsepower for improved overall boat performance. You can use an XR but you will loose around 100-160 HP on a twin application. That is a HUGE loss. The # 6's swept-back Dry-Sump Six drive improves handling and overall boat performance at higher speeds. The innovative "dry-sump" lubrication system features a precision-oiling pump that sprays a metered portion of oil to lubricate vital internal components. I think personally that anything over 500 HP needs the #6's. I wouldn't buy a boat without them if you plan on going to 550 HP and up.
    525 EFI are fine with XR's. #6's for everything above. Plus the 6's look so cool and are so very efficient. Why loose 10% per engine at the prop with XR's if you have the $$ for a 550+ HP engine??
    Attached Images Attached Images
    Support our President; Support our Troops.
  3. #43
    Member #2 ....Jeeezz Charter Member cigarette1's Avatar
    My Boats:
    Toy Boat - Toy Boat - Toy Boat
    Join Date
    Oct 2000
    Kicked to the curb
    Big big big difference between an XR and a #6 setup
  4. #44
    RHC is offline
    Registered RHC's Avatar
    Join Date
    Oct 2002
    Sandusky Bay
    Drives::: This months Powerboat Mag has a blurb about Mercs new Bravo for 2005,,,, has a reinforced upper and some inuendos about other upgrades ,,, One should not lump all Bravos in the same conversation::: The XRs are very good and now with the upgraded case structure it will be even better,,,, some of the aftermarkets IE::: Max Machine and Imco have good products also,,,,, Too many Guys just try to add horsepower and not upgrade the drives ,,,, then they put the big power in heavy boats and the problems start!! Thats in my opinon of course!! We have over 200 hrs on upgraded XRs and plan on going thru them after this season,,,, easy up, easy down,, Run as hard as u want after that !!!!
  5. #45
    Uh.. Hydrocruiser, you're confused #6's and tranny's INHALE HP ! The parasitic drag and weight of the #6 package will cost the typical rig 5 mph at a minimum ! Thats why THE DAMN BRAVO BOATS ARE SO FREAK'N FAST ON SO LITTLE HORSE POWER!!!....... till they break.
  6. #46
    Join Date
    Apr 2001
    You are right about the tranny (at least the hydraulic shift ones), but the MC6 actually uses less hp than a Bravo, and the difference increases with rpm. The problem with the MC6 is mainly drag, it's got an awfully big skeg. Look at how some notice the difference between the Sportmaster Bravo and the IMCO, mainly because of the slightly larger skeg on the Sporty. Also the MC6 is turning some very heavy props designed for much more hp and of course the package weight, especially with the cast iron cased tranny. Some of the teams in SC Light that have switched to the MC6 have suddenly noticed more parity by running a crash box and having less weight penalty. Another issue is that many boats are really designed around Bravos and weight placement and step location for the MC6 packages isn't really optimized.
    I just wanted to point out that it isn't really hp to the water that is the difference.
  7. #47
    I'm not sure about the Bravo not being up to 600hp. I have 600 hours on my Bravo I with the last 1/3 bolted to a 625hp 540ci. The XR should be up for the challenge. Mercs abuse tests for drives are obscene! I spoke to Cummins about a possible TD setup for a performance 36-40' and the big problem was the drives. Merc did not want to mate the drive to 700lb ft of torque. The cummins guy said the drive was tested and failed. The test was full power cycling in and out of the water to simulate full load / zero load conditions for offshore. The drive failed at something like 800 hours instead of the 1000 required. I understand that Merc is conservative and wants to deliver an indestructable product, but man, this is rediculous.
Similar Threads
  1. BYE BYE 312 Stinger
    By prostock85 in forum Chris Craft
    Last Post: 10-13-2008, 10:27 PM
  2. Bye Bye Dodge, Hello Sierrra
    By GregP in forum General Boating Discussion
    Last Post: 01-31-2005, 09:22 AM
  3. bye bye fishing boat
    By Open72 in forum General Boating Discussion
    Last Post: 11-07-2004, 06:30 PM
  4. Alpha uppers went bye bye- opinions please
    By bucky in forum General Q & A
    Last Post: 08-30-2002, 09:19 AM
  5. Parts 4 sale section going bye bye !!!
    By Chris288 in forum General Boating Discussion
    Last Post: 06-10-2002, 10:16 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
