View Poll Results: What oil do you use in your stock power big block ??
25-40
51
9.01%
15-40
28
4.95%
20-50
87
15.37%
straight 40
90
15.90%
straight 30
19
3.36%
syntec
9
1.59%
mobil 1
183
32.33%
amsoil synthetic
45
7.95%
R.P.
21
3.71%
OTHER
33
5.83%
Voters: 566. You may not vote on this poll
POLL: which oil do you use ?
#61
Re: POLL: which oil do you use ?
Regardless of what engine, lots of benefits seen from switching to Alisyn drive oil. I gained 2 mph on a V6 boat, 454 mag nova gained 4mph.
#62
My 15-40 Diesel oil experiment has ended,, and I will not be using it any longer in my 496.. going to stick with Castrol syntec synthetic blend 20-50.. After a VERY hard hour long run at lake champlain I found my oil pressure's at idle dropped quite significantly,, seems the lighter weight cannot keep the pressure up when it get hot..
#63
#64
At the TMP shop they use 20-50, and tell all their customers to change every 10 hours. I have a quick oil change set up on the motors so it can be done in 30 minutes from filter to refill, plus it keeps my 1 year warranty in effect, to me oil is cheap insurance. Jeff
#65
Just giving up on 15-40,,, it's not enough oil for our motors, after long runs, oil pressure suffers.
Wondering if mobil 1 15-50 will do the same ??
#66
#67
ALISYN. its around 10$ a quart. On just drive oil (Alisyn Type 1, compared to merc racing) I gained 2mph on radar, I also had more gas than my previous best time pass.
#68
Found a lot of information about Alisyn HERE: http://www.aerospacelubricants.com/c...listing=Marine
Tommy, wondering which gear lube you used in your outdrive ??..
