View Poll Results: Who makes the best blower/supercharger?
Voters: 371. You may not vote on this poll
#101
Re: Who makes the best blower/supercharger?
Originally Posted by tomcat
Turbo, centrifugal, screw, roots...that's the order of HP at high RPM. At low RPM it's screw, roots, centrifugal, turbo. Anyone trying to decide which way to go needs to consider the shape of these curves and relate them to their needs. There's a blower type to suit everybody, but as was mentioned by several previous posts, more torque at low RPM is not always necessary or beneficial.
Tom
Tom
I think "the best blower" is the one that delivers the most trouble free hrs., (build quality/reliability). Engine life depends on if the internals are compatable with the chosen blower, maintenance, and how it is driven.
#103
Here's the latest dyno sheet. Stock 540 Bulldog - 500 HP brought up to 800 HP with hot air entering the blower from the dyno headers. If you correct to standard conditions (60F) like everybody does, it's about 850 HP, no accessories. Shape of the torque curve is the result of boost increasing with RPM, compensating for the heads and cam which are falling off.
#104
Caution, blower porn:
W305R (radial entry)
Can run single, dual or triple carb, throttle bodies, bird, buzzard or condor injectors, etc:
Notice the prototype 16-rib serpentine belt system.
We are very behind schedule on these, but well worth the wait. From the current numbers, were 30-40hp OVER the PSI with 3-4lbs of boost LESS!!!! We will have some production units in November. Prices will be released in 2 weeks.
Thank you,
Dustin
Thank you,
Dustin
#107
What are the discharge temps vs. the water temp.and air temp. in...at what boost???....do you answer the phone faster than rodger ???...How much can you over drive this unit??...100 percent??
#110
Originally Posted by JCPERF
Very cool Dustin.When can i get 2?
