Who makes the best blower/supercharger? >
View Poll Results: Who makes the best blower/supercharger?
The Blower Shop
17.52%
BDS
9.70%
Mooneyham
2.70%
Dyers
0.54%
Weiand
1.89%
Holley
1.08%
Littlefield
5.93%
Whipplecharger
43.40%
Procharger
11.86%
Vortech
5.39%
Voters: 371. You may not vote on this poll
Old 07-11-2004, 10:53 PM
  #51
26ZX Donzi's Avatar
Default Re: Who makes the best blower/supercharger?
Real world -limited resources (poor by OSO standards)-stock not exotic! I purchased a Vortech based system from Livorsi Marine (ask for Ron Harris). It came with a modified ECU, Vortech charger, intercooler. I now have over 200 hours on the motor since adding the system. Real world: blew the outdrive once - blew the head gasket once. Would I do it again? YOU BET! Went from 64gps in a 26 Donzi to 77-79gps. Wanna play you got to pay. This still seems to be one of the most reliable, cost effective systems out there. HOWEVER - To each his own!
26ZX Donzi is offline
Old 07-12-2004, 09:03 AM
  #52
I love this question... and I hate this question too. So many variables and potential contradictions. But here we go.
The best blower system needs to:
1) Give the greatest HP/speed gains
2) Not blow up your engine
3) Give your drive a chance to live
4) Be good value for the money
5) Be easy to install on nearly stock engines
6) Look good!
Sticking to nearly stock engines makes things more affordable and easier to install, but it eliminates purpose built, big $$$ blower engines with PSI or Quad rotor screw compressors. The contest is between Roots, Whipple and Centrifugal, using the criteria listed above.
IMHO, only the centrifugal blowers can make the big HP numbers on nearly stock engines. They have high compressor efficiency and the way the blower is mounted on the engine leaves room for a huge intercooler. This is very important because detonation is the real limit to how much HP you can make, and the coolest possible intake temperatures are needed.
Dean Nickerson gets 950 HP @ 6000 RPM from a Vortech V-4 blower and a single carb on a 498 CID engine with ported GM cast iron heads and a small solid roller cam. Before installing an Rtech supercooler he was making 850 HP. The extra 100 HP with the supercooler is partly due to cooling but also to much lower restriction to air flow. The same Rtech system on a stock HP500 will make 800 HP @ 5600 RPM. This is affordable $/hp. Dean is still using his stock Bravo drive, although I don't see how it can last much longer.
You could make 950 HP with an intercooled 14-71 on the same engine but you would need much better aftermarket heads. The better heads compensate for the lower efficiency of the roots blower and the small roots intercooler. But the heads would cost more money and the Roots system would be more likely to wreck your drive. The single Whipple has great bottom end torque but you can't make this much HP with a single Whipple, and the Quad rotor would cost more money.
As far as looks go I'm biased. I think the supercooler looks much better than the usual plumbing found on centrifugals, but I know many prefer the look of the roots blower.
That's my $.02. You can easily change my conclusion by changing the emphasis you place on each of the above variables; that's what makes the question so difficult to answer. Any time the magazines try to approach this issue, there is a lot of such debate and usually "everybody is a winner".
There's only one thing for sure...you need a blower!
Tom
Attached Thumbnails Who makes the best blower/supercharger?-engine-front.jpg
tomcat is offline
Old 07-12-2004, 09:22 PM
  #53
What... nobody wants to start an argument, I mean discussion.
tomcat is offline
Old 07-12-2004, 09:37 PM
  #54
mikes280's Avatar
would you like to see my dino sheets on a 540 with a single 3.3 whipple try 1067 hp at 5700 and 1128 ft. lbs. one 1180 cfm carb
mikes280 is offline
Old 07-13-2004, 07:34 AM
  #55
Registered User
Originally Posted by CigaretteFirefox
Did they quote a reason?
Better overall performance on your motor.
MIAMIBOYZ is offline
Old 07-13-2004, 07:37 AM
  #56
Registered User
Originally Posted by SR-24
Thanks for the replies. There is some good info here.
MYPANTERA28, what was the reason the engine builders you know were removing Whipplechargers?
Thet dont trust them for sh^&.
Old 07-19-2004, 10:04 AM
  #57
Hi Mike:
It's always hard to compare blowers because it seems they are always installed on different engines (heads, cam, displacement, headers etc.), which changes the restriction to air flow that the blower is working against. I'm not saying that your 540 (with aftermarket heads?) didn't make 1067 HP, but if you put your 3.3 Whipple on Nickerson's 498 with cast iron heads you would not be able to make that much power. It would take too much boost to do it and the heat/detonation would be the limiting factor, as it always is.
Any positive displacement blower must be sized to the engine HP you're after. That's why there are 14-71 and quad rotor Whipples. Whipple rates the 3.3 at 775 HP on the HP525EFI. At 1067 HP you're getting into quad rotor territory. This doesn't stop you from changing pulleys and spinning your 3.3 faster, but it is a case of diminishing returns. When we dyno tested Nickerson's engine we tried a smaller pulley and made 1013 HP but he didn't leave that pulley on the engine.
One little-known advantage of centrifugal compressors is that they are much more flexible on the HP range. The same V-4 blower that we used to make 1000 HP on Nickerson's engine is used in Vortech's basic 502MPI kit to make 570 HP. This means a guy can get started with the basic kit, and when he is ready to move up he doesn't need to buy a bigger blower.
I guess the only way this question can be decided is to test different systems back to back on the same test engine, same dyno and ultimately in the same boat. That's way too much work/money, except maybe for a magazine. I doubt that it will ever happen, so we will be able to argue (I mean discuss) this question forwever.
tomcat is offline
Old 07-22-2004, 07:15 PM
  #58
Does Mercruiser actually build their own blower or do they use one of the above mentioned?
I have the Mercruiser SC600 in my 26' Scarab #5 drive. The Blower is the B&M 420 Mega Blower!
Bryan
bpine is offline
Old 10-03-2004, 09:26 PM
  #59
Reed Jensen's Avatar
Originally Posted by mcollinstn
DaveF
Sure, MercRacing hand-assembles their blue blower motors, but they don't "build"/manufacture the parts. A question was asked if Merc builds their blowers, and the answer is NO. They use sourced parts that are the same pieces we can buy ourselves (some do have a special merc emblem on them).
Merc DOES "build"/manufacture outdrives, but assembles motors.
Not trying to dismiss anything of Merc, just pointing out that while Merc DOES have some "Merc-only" parts, they are stuff like outdrives, exhaust manifolds, tstat housings, and cable brackets - not special blowers, blocks (other than the big aluminum 4 they made years ago), heads, pistons, etc..
Merc may "build" the drives... but they have the cases cast by someone else... I've seen the brochure of the company that casts the components.. No one... no company makes everything on a car or a boat... It just isn't economically feasible. Some companies that specialize in unusual components can make the parts much easier than a large company. When people say "Lockheed" built the F-117 Stealth fighter... well... they assembled it... and made the airframes... but lots of first and second tier vendors manufactured the components... Same with Mercruiser.
Reed Jensen is offline
Old 10-04-2004, 08:53 AM
  #60
Sorry for the offtopic, but...
Reed:
What company cast mercury's outdrives?
vtec
vtec is offline
Quick Reply: Who makes the best blower/supercharger?
