If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Re: Ideas on why my Air conditioning in my truck doesn't work
    sounds like no orifice tube in system e/mail me i could fax you a diagram off mitchell seeya
  2. #12
    Registered rjcardinal's Avatar
    My Boats:
    '99 27 Fountain Fever
    Join Date
    Jan 2001
    Baton Rouge, LA
    If the system was open after the collision they may have only changed the broken parts and left the receiver/dryer open to the atmosphere during the repair. The receiver/driver will absorb moisture and most vacuum pumps wont be left on long enough to pull the moisture out of the dryer. So the dryer may be comprimised and limiting the systems potential.
  3. #13
    Platinum Member Platinum Member mcollinstn's Avatar
    My Boats:
    1991 F311SR1
    Join Date
    Sep 2001
    wow. odd.
    Are you checking the high side before any filters or screens? (make sure you are, or if not, then that filter may be full of crap).
    Orifice tube missing or torn. This is the main part that creates the high/low pressure separation. Right after the orifice tube, you would measure the lowest pressure in the entire system (if it was running and you had a pressure port there, which you don't).
    Clogged dryer/filter would show low pressures on the low side, I think (I can't remember if the pressure port is before or after the screen on the dryer..).
    Clogged or restrictive condenser would show high high side pressures.
    Lack of a proper high low differential sounds to me like an expansion valve problem. GM's don't use expansion valves on most products, and instead use a metering orifice called an orifice tube. They make different sizes for different models (color coded) and you might have the wrong one...
    It definitely ain't right.
    And yes, bad compressor COULD cause the problem you're having, but I sort of don't think it is the compressor's fault.
    Doesn't matter, insurance should pay to fix whatever it is, unless they can show that it is an unrelated problem. I've had Allstate go back and fix peripheral systems after crash damage. They were pretty good about it.
    I see London, I see France...
  4. #14
    Registered Airpacker's Avatar
    My Boats:
    little cat...BIG MOTOR
    Join Date
    Aug 2001
    Aurora Ontario
    It sounds like the orifice tube may have been left out or is an old R12 type(wrong size) because the 96 body style uses the same condensor as an 89 thru 93 which would have been an r12 vehicle. If it has an r12 orifice tube in it, the low side pressure will be high and the high side will be low. Many aftermarket condensors came with an r12 tube in them because they are OLD stock pieces. One other possibility is that a chunk of garbage became lodged in one of the compressor valves due to the collision or the repair.
  5. #15
    OPA is offline
    My Boats:
    Join Date
    Apr 2002
    If Your A/c Light On The Dash Is Blinking You Need To Change
    The Switch On The Dash It Cost $169.00 At The Dealership I Just Went Through The Same Thing.
  6. #16
    Registered phughes69's Avatar
    My Boats:
    1980 Wellcraft Scarab 377 twin turbo, 1984 Formula 242 LS SBC/ Alpha
    Join Date
    Dec 2001
    St. Clair Shores, MI
    No blinking light on the dash. The colision shop said they do not have the expertise to fix it, so now I have to get a hold of the insurance company and see what they want me to do.
  7. #17
    Charter Member#1545 Charter Member
    My Boats:
    Join Date
    Mar 2001
    Grand Junction, Co.
    Any good AC shop will get you going quickly. My money is on the expansion tube like I posted earlier. The job should not take more than a couple of hours at most. Sam
Similar Threads
  1. air conditioning
    By morgansrun in forum General Q & A
    Last Post: 10-11-2008, 09:11 PM
  2. air conditioning
    By morgansrun in forum Baja
    Last Post: 03-01-2008, 04:10 PM
  3. air conditioning
    By drgnrydr in forum Eliminator
    Last Post: 03-01-2006, 05:29 PM
  4. Air Conditioning???
    By RebarBox in forum General Boating Discussion
    Last Post: 05-13-2004, 12:39 PM
  5. Air Conditioning
    By Quiet Storm in forum Sonic
    Last Post: 07-18-2003, 03:22 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
