If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: nitromethane
  1. #31
    Platinum Member Platinum Member mcollinstn's Avatar
    My Boats:
    1991 F311SR1
    Join Date
    Sep 2001
    Re: nitromethane
    Toluene does nothing for increasing power.
    It is only effective as an octane booster, which ALLOWS you to tune for more power but does nothing in the way of ADDING power on its own in an otherwise unchanged engine.
    Oxygenated fuels DO make more power (with a minor jetting change).
    As we all know, a motor can only pump "so much" air into itself. Cams and porting can help it pump a bit more, but it is still the main limitation. We can add only as much fuel as we can effectively burn and this is the ceiling on the power we can produce.
    Adding liquid fuels that also contain oxygen act just like increasing airflow thru a motor (supercharging) because it increases the available oxidizer in the combustion chamber.
    Nitromethane is very close to being able to burn on its own without additional oxygen. This is what makes it so good. At fuel air ratios as low as 1:1 it provides MASSIVE power.
    Oxygenated "cheater" fuels act the same way, only on a lesser scale.
    Toluene has an effective octane of around 117. Is not oxygenated.
    I see London, I see France...
  2. #32
    My Boats:
    1999 Mystic 32 cat
    Join Date
    Dec 2002
    cincinnati, ohio
    Re: nitromethane
    I didn't think you could mix nitro with gas. I thought a blending agent was necessary such as alky to keep the fuels from seperating. Some great stuff if you can manage it!
  3. #33
    Registered Sonic30ss's Avatar
    My Boats:
    1987 Sonic 30 SS 1998 45' Wellcraft Excalibur
    Join Date
    Oct 2002
    Re: nitromethane
    I've run about a pint to 15 gallons of 110 race fuel, in my Hemi, it felt a little stronger, but boy did it smell good : ) I did not want to put too much in it, as I knew what would happen BANG! A friend put a can of Klotz in a big inch small block Mopar and at the end of the run there were no electrodes left on the plugs (and no rings left on the pistons!) Moral BE VERY conservative and pay attention to jetting and timing!!!!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
