If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 5 of 5
  1. #1
    bn is offline
    Registered Platinum Member bn's Avatar
    My Boats:
    260 Formula SS
    Join Date
    Oct 2000
    Syracuse, NY
    Unhappy Labbed Bravo Props Cracking
    I had my 26P Bravo 4 blade props labbed this year and back in July one of the blades on the left hand prop cracked after running the boat. I called the place that labbed them and was told that left hand bravo’s are known for cracks. I took it to a local shop for repair and the local guy said that these props were WAY too thin and he repaired it. (I took the prop to the local shop for a quick turn around)
    Later in the summer I noticed that 2 more different blades on the same left hand prop each had a crack in them. I took the prop to the same local shop for repair. That is a total of 3 blades on the same prop that had to be repaired.
    Now, I have noticed that the right prop has a good size crack in one of the blades and the first crack that I repaired on the left hand prop cracked open again.
    I called the place today that originally labbed the props because I wanted to hear an explanation for the right prop cracking since I was originally told that “left hand bravos are known for cracking”.
    The prop place now tells me that “bravos are known for cracking”. I explained that I ran these props all last year (put about 45 – 50 hours on them) and had no problems. I told him that I truly believe that if they didn’t lab my props that they would not be cracking as they are REALLY thin now.
    I asked him to send me a new or used set of props and they declined. He gave me a price for a new set and I said how about we split the cost – I will pay for one and they will pay for one. Answer was still no.
    He said that he has fixed cracks for other people and they have never come back. So I asked about him fixing both of mine now and he said no because someone else has worked on them. But the local guy has only worked on one of them. So they told me that they would fix one of them.
    My question is, what is the fair answer here? Should I be given a new or used set of props? Should he at least offer to fix both of them?
    I borrowed a set of the same size props that were labbed by Merc and they performed almost the same (within less than 1 mph) but had a lot more meat on them. They are not NEARLY as thin as the ones that I had labbed.
    Also, anyone have any 26P Bravo's that they want to sell?
  2. #2
    Registered dreamer's Avatar
    My Boats:
    boatless... with money in the bank!!
    Join Date
    Mar 2002
    Re: Labbed Bravo Props Cracking
    labbed props crack... thats that... or are prone to crack... anyway its like all performance mods void warr. and fix at your cost... sorry
  3. #3
    Rob VIP Member Strip Poker 388's Avatar
    My Boats:
    Hustler 388
    Join Date
    Aug 2001
    I am losing them on a the stock bravo props also. I just cracked one this week end .Here is the link on what I had. Mine are Not labbed .I could not imagine if they where labbed
    Losing prop blades
    Attached Images Attached Images
    Boost makes up for Cubic Inchs
  4. #4
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ..........32........... Active Thunder
    Join Date
    Oct 2000
    Labbed and higher pitched props are more prone to crack than stock lower pitched ones. Labbing weakens them and there is also more resistance and force needed to spin higher pitched props.
  5. #5
    Platinum Member Platinum Member CigDaze's Avatar
    My Boats:
    Cigarette 35 Cafe Racer
    Join Date
    Jun 2001
    St. Petersburg, FL
    Props cracking are a fact of life. Blades are like slender cantilevered beams with high loading at the root, which happens to be very cyclical. By labbing the blades and thinning them, you further exacerbate the problem by lowering the bending resistance and drastically decreasing the fatigue life. Labbed props are life-limited devices.
Similar Threads
  1. 28p bravo 1 labbed props ?
    By 26sonic in forum Sonic
    Last Post: 08-08-2006, 10:37 AM
  2. looking for bravo 1 28p labbed props?
    By 26sonic in forum General Boating Discussion
    Last Post: 06-01-2006, 08:35 AM
  3. Labbed Bravo Props and intercom system on Ebay
    By LubeJobs42 in forum General Boating Discussion
    Last Post: 11-16-2003, 08:45 PM
  4. need to get bravo props labbed
    By dreamer in forum General Boating Discussion
    Last Post: 05-02-2002, 05:35 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
