New found power!!!!
Old 09-15-2004, 08:20 PM
Gone Fishin'
Waterfoul's Avatar
Thumbs up New found power!!!!
Runs smoother, and no more spark knock! I finally got around to changing the plugs in my Dodge. It's been spark knocking for some time now... shame on me
The one on the left is a properly gapped plug at .040" (an old one I took out and re-gapped). The one on the right is about the average of what I took out (I didn't touch this plug, it came out that way), about .070" or so.
What causes this???
'Foul
Waterfoul is offline
Old 09-15-2004, 08:24 PM
Default Re: New found power!!!!
Looks to me like someone had too many polish pops when they decided to go out and put new plugs in the motor!!
WETTE VETTE is offline
Old 09-15-2004, 08:29 PM
Gone Fishin'
Waterfoul's Avatar
HEy, they were all gapped correctly when they went in.... about 80,000 miles ago... again, shame on me.
Old 09-15-2004, 08:40 PM
If the engine is a 5.2 or 5.9 and even the v-6's the will blow the intake plenuim gasket and carbon up the motor and spark knock. (Internal vaccum leak) We fix alot of them at the dealership.
Terry
runnin gun is offline
Old 09-15-2004, 08:44 PM
Gone Fishin'
Waterfoul's Avatar
5.9 and I had that checked once before... it was fine. I'm just wondering why the gap get's blown out like that??
Old 09-15-2004, 09:52 PM
Official OSO boat whore
Hmmm...never had that problem...
Cord is offline
Old 09-15-2004, 10:12 PM
Gone Fishin'
Waterfoul's Avatar
So how often do you change your spark plugs Cord?????
Old 09-16-2004, 08:04 AM
Downtown42's Avatar
97 2500 - 5.9 - 86k... I change plugs every 40k range. Had to re-bearing my entire rear diff last month. And running synthetic lube to boot
Downtown42 is offline
Old 09-16-2004, 08:15 AM
robyw1's Avatar
the electrode was eaten up by the knocking cylinder causing the increase in gap. Other than being worn out they don't look bad. .060 is not an uncomon gap for a late model car or truck. What attributes to it also is that cylinder running a little hot causes the ground to get soft and sink. Not uncommon at all
Roby
robyw1 is offline
Old 09-16-2004, 09:57 AM
Charter Member #655
dyno's Avatar
and I thought you had the Baja runnin.....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Quick Reply: New found power!!!!
