Max Tow Capacity Z-71 Suburban V-8
#51
Re: Max Tow Capacity Z-71 Suburban V-8
Originally Posted by t500hps
Also, I hauled this same 12,000 load from Cleveland to VA with a 04 6.0L diesel F350 and didn't know the load was back there. I currently have a 10,000 boat, trailer, gear and it can get a little squirrely. Forget the bags and gears....step up when you can do it right or find a marina w/ on-site storage.
Russ C.
Russ C.
#52
21 and 42 footers
Originally Posted by BLOWNBOAT
I dont know how you guys do it. I picked up a boat from st luois and it weighed 10000 and pulled it to Arizona with the same ford and we knew it was back there the whole time. Dont get me wrong it pulled good but we only got 7-9 miles to the gallon . That was it.
#54
[QUOTE=RollWithIt] Currently I am bouncing between a 3/4 ton Ram with the V10 and a 1 ton F350 with the Diesel. Both will tow in the 12k lbs range.
QUOTE]
I just bought an F350. Tow rating is 17,000 ponnds.
QUOTE]
#55
I've got an 03 2500 suburban 6.0L and 3.73. Chevy says it's rated at 7,600lbs. Rating goes to 9,600 with 4.10. I have hauled 12,000 lbs for local trips and it's ok, but 70 on the interstate is it unless you stay in the passing gear. Not sure about a 1/2 ton, but it's probably only a little less. (Huge difference in how much tongue weight it will carry!)
Russ C.
Russ C.
"All I need are some tasty waves, a cool buzz and I'm fine"
