Powder coating drives
I need to have my drives/mid section of an outboard powder coated.
Can it hold up to high temps ? Does it last in salt water with heat ? Thanks, Curtis |
Re: Powder coating drives
there is another thread on this ..........I think "painting drives" ... I PC'd one of my drives about 6 months ago and so far no problems .. But if your drives have any corrosion now it will be visible with the PC unless you do a lot of prep before hand or mutliple PC coats ..... Also need to use a procedure called Gassing which is heating the metal before painting ...if not the corrosion will continue under the PC' .
