HELP, Adhesive removal
Old 02-14-2005, 04:56 PM
formula31's Avatar
Default Re: HELP, Adhesive removal
3M adhesive remover, can be bought at NAPA or any other auto place. Apply it let it work and soften the glue, then, use a hardcard/ Squeegee to remove the glue...
Rob
It works good but I think I spent $25 a quart on the stuff. Im pretty sure it is nothing more than lighter fluid at a couple bucks a pint. Thats all I use now. (dont smoke)
formula31 is offline
Old 02-14-2005, 05:44 PM
i always thought body shop guys used a heat gun or hair dryer to remove adhesives ?
Don
chromecat is offline
Old 02-14-2005, 06:38 PM
offshoredrillin's Avatar
Received 1,295 Likes on 449 Posts
Its 6 dollars at NAPA, there is stuff thats more potent, but this wont affect paint or gelcoat. When I remove film from someones car, I sometimes need it. being patient with it is the key, allowing it to penetrat the adhesive.
offshoredrillin is offline
Old 02-14-2005, 06:59 PM
Formula Outlaw's Avatar
Originally Posted by 42MTI
I have taken the mirrorred plexyglass out of my hatches but am having trouble getting all the adhesive off.I have been trying a plastic putty knife so not to scatch the fiberglass but it is going very slow.I think it is something called 5200.
C4
5200 is a bit(h to get off no matter what you use. The "5200" Remover works, but it's still a lot of elbow grease involved.
Good luck.
Formula Outlaw is offline
Old 02-14-2005, 08:07 PM
H2Xmark's Avatar
Originally Posted by US1 Fountain
West Marine carries 5200 remover. Worked most excellant when I used it.
you are right, the only thing that will get this stuff off is Anti-Bond 2015, it is a spray can that is made to dissolve all polyurethane based adhesives and sealants, it sells for 9 bucks at west marine, model#1174804
H2Xmark is offline
Old 02-14-2005, 08:11 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
That's it...........Anti Bond.
Like mentioned before, has to soak in for it to work.
US1 Fountain is offline
Old 02-14-2005, 09:45 PM
mcollinstn's Avatar
5200 is not "glue" or "caulk". It is mega-strength polyurethane and it will bond itself to just about anything, including mirror polished stainless steel, plastics, and it even tries to stick to greasy surfaces.
Adhesive remover is only a tiny bit better than nothing.
Anti-bond was expressly designed to kill 5200. But it's like wallpaper remover. You gotta razor blade off the bulk of it, then work from the edges inward with the AntiBond. But it WILL get it.
mcollinstn is offline
t500hps
09-05-2008 08:25 PM
waterboy222
11
06-26-2008 07:38 PM
boatnt
03-07-2008 06:57 AM
Danny_Ocean
6
05-13-2004 07:56 AM
Steve A.K.A RAMPAGE
05-19-2003 02:41 PM
Quick Reply: HELP, Adhesive removal
