will not trim up?
will not trim up?
took my new to me boat out for first time today I have a problem with one of the drives not trimming up you can hear the relay click but will not go up any suggestion what to look for also pump is very hard to get to. The trim did work part of the day.
21 and 42 footers
Re: will not trim up?
I assume you checked the fluid level. I remember an outboard boat we had once had a solenoid go out. Trim worked one direction but not the other (don't think that's relevant here though)
At least your maiden voyage was a little less costly than mine
Is the seloniod putting power to the pump when it clicks....beat on the pump while someone is clicking it or your jumping it ...make sure the pump is trying to work and you have a cylinder problem..beat on motor.
zimm17
3
03-13-2007 05:23 PM
JGB
21
09-28-2004 04:30 PM
