Need some help
Need some help
I put an alternator on my port motor a couple weeks ago. my dumbass forgot to turn the battery switch off, and the hot wire touch the alternator when i took it off....caused a bit of a firework show down there. i never tried to start the motor because i have been working on a few different things since then. Tried to start it on the hose today and i had no power at the key. the stbd. motor has power and can run. I put a test light on everything a figured out i don't have any juice at the main circut breaker on the motor.
is there a fuse somwhere inline that goes from the starter up to the that box on top of the motor where the main circut breaker is ?????
I hate the winter!!
Re: Need some help
There is a main circuit breaker on the starter motor battery terminal. It doesn't look like a breaker, it looks like a hunk of plastic on the top stud of the starter. I think it is 90 amp. Also, there should be a 50 amp resettable breaker somewhere on the top of the engine. If I recall, it should be towards the back of the intake.
Re: Need some help
Thanks for the info.
Was looking for that 90amp fust yesterday. Problem is there is no good way to get to the starter in this boat. I can barely get my hand into that area without tools.
Is there anything else i can check that would cut off power to the motor? I checked the main circut breaker on top on the motor with a test light, and have no power to the hot side of the breaker. Boat is 96 35 Soinc. Could there be a main breaker or other fuse i may be missing.
