Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-13-2005, 04:20 PM   #1
gotime34's Avatar
36' RXT WARLOCK CAT
Question Rub Rail, can I do it myself?
The rub Rail on My 34' Scarab has seen better days. I need to change it but want to stick with the chrome/stainless look. Can I do it myself? To me it just looks like a lot of holes to drill and a little bending around the corners. Where can I get the material? Any tips or techniques? Thanks in advance for any help.
gotime34 is offline   Reply With Quote
Old 06-13-2005, 04:47 PM   #2
Charter Member #232
Audiofn's Avatar
1979 Formula 302
Re: Rub Rail, can I do it myself?
There are a few places to get the Material. Taco is the most popular. It is not real hard it is time consumming. Put the plastic filler in hot water to soften it. Push it in don't pull it in or else you will have a issue with the rubber shrinking.
Jon
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Sponsored Links
Old 06-13-2005, 05:45 PM   #3
30 motion ob
Check your screw centers.Try to match the new rub rail to the old. Will make your job much eaiser
mmwalters is offline   Reply With Quote
Old 06-13-2005, 07:18 PM   #4
hillbilly24's Avatar
also when making the bends don't try and do it off the boat. Screw it on until you reach the point that it needs to be bent then just use a dead blow hammer to gently work it around.
hillbilly24 is offline   Reply With Quote
Old 06-14-2005, 09:40 AM   #5
Were doomed!
Wally's Avatar
Chris Craft Stinger 222
More then likely alot of the screw hole wont line up.....in that case either 5200 them closed or epoxy them so you dont have any problems with water getting in
-Wally
The dollar decides how far you can go....
AOL IM: bigblockwally
Wally is offline   Reply With Quote
Old 06-14-2005, 10:11 AM   #6
SORE MEMBER
Wobble's Avatar
Kawa 1100 ZXI, SeaDoo RXP Stryker Equalizer 2800
Quote:
Originally Posted by gotime34
The rub Rail on My 34' Scarab has seen better days. I need to change it but want to stick with the chrome/stainless look. Can I do it myself? .
No,
2 man job + attractive beer and pizza runner minimum.
Helped a friend do a 27 Pachanga, went back with the solid white nylon type molding. Where we drilled and countersunk holes where we wanted them. You might as well forget most of the previous screw holes except one where you start. We filled all holes with marine-tex. That way if you hit previous holes screw still bites hard.
Lots of tape and patience, hot water and heat guns are good too.
Mark,
Wobble is offline   Reply With Quote
Old 06-14-2005, 03:36 PM   #7
gotime34's Avatar
36' RXT WARLOCK CAT
Dammit, sounds like more work than I wanted to hear. There will be 2 of us, and there will definately have to be cold beer.
Old 06-14-2005, 08:03 PM   #8
aTX427's Avatar
Fountain 42 Lightning - 700sci / #6 dry sump
It is a lot easier than you think. Two of us did my 38 in one weekend. Don't bother trying to line up the old holes, just 5200 them and drill new. I used Taco white base with an SST insert - if you do the same use 1" long #6 screws on both the base and 1/2" #6 on the insert. A heat gun worked real well on the base and dead blow on the insert. Like the others said screw it on then form it around the corners.
aTX427 is offline   Reply With Quote
Old 06-15-2005, 07:36 AM   #9
gotime34's Avatar
36' RXT WARLOCK CAT
Awsome, Thanks for the help. Looks like I'll be doing that next weekend.
Old 06-15-2005, 07:46 AM   #10
Charter Member #232
Audiofn's Avatar
1979 Formula 302
When I replaced mine instead of using screws I through bolted all of them except three in the very bow that I could not reach. This way I never have to worry about the screws backing out ever again....
I think that they were 10/24's with washers and nylock nuts on the inside.
Jon
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
help i need a new rub rail noone seems to be able to help me dj_merk_e Scarab 14 02-20-2008 12:19 AM
Rub Rail GO4BROKE Sonic 5 12-05-2007 10:43 PM
New rub rail onesickpantera Pantera 5 11-05-2007 11:08 AM
Rub Rail Boomer35 General Boating Discussion 10 12-09-2005 09:59 AM
And a Rub Rail Boomer35 General Boating Discussion 2 06-21-2005 08:29 PM
Search Engine Optimization by vBSEO 3.2.0
