what would 496/ho do without resonators
i think i have a bad resonator (sounds like exhaust leak, but can't find one). what would happen if i removed them.
i figure it would run leaner, but would it be dangerously lean?
do you have to re-calibrate ecm if you add headers?
Re: what would 496/ho do without resonators
My Question Is ;will Removing These Items Cause Bad Water Reversion With The Silent Choice/muffler Option In The On Position ????
NO, the resonators and restrictor plates do not affect reversion and stock 496 engines do not develop reversion. If your exhaust tips are below the bottom level of your risers bottoms you should not develop any problems with these items out, unless your boat sits in the water between uses a lot, especialy if its in salt water.
Ray @ Raylar
Ray @ Raylar
"raylar" My Boat Sits On An Electric Lift Slip In A Salt Water Environment/ Md. Chesapeake Bay Area,
Will It Be Ok To Remove Them In This Type Of Environment? What Kind Of Performance Gains Should I See In A 2004 31 Sonic With Twin 496 Ho's ????? Thanks For The Information !!
TeamPSI
23
12-10-2007 05:23 PM
