Amsoil Products >
Amsoil Products
Amsoil Products
Old 08-31-2005, 02:17 PM
Hydrocruiser's Avatar
Arrow Re: Amsoil Products
Originally Posted by Firewalker
I cannot speak for there 4 stroke oils, but as an 2-stroke engine builder, I can say it is one of the worst oils I have seen.
You can ask almost world class engine guy and you WILL get the same response.
Blue bearings and worn cylinder walls and rings. It is OK..... in a 200 hp motor that turns low ( sub 6000 ) rpm. But if you are building real power ( which requires RPM ) the stuff doesn't cut it.
Look too Redline, Klotz, or my favorite Alisyn.
RT
It is interesting in that we have heard this from others as well.
Hydrocruiser is offline
Old 08-31-2005, 02:19 PM
Firewalker
Default Re: Amsoil Products
Oh, I should state....... I do run Amsoil in my sled, but NEVER in my Hi-per outboards. I run it in my sled because you can buy it everywhere.
RT
Old 08-31-2005, 02:25 PM
I still like the Amsoil 2-cycle oil called Sabre for lawn equiptment. You can go down as low as 1:100 for all applications but I have found 1:64 to be a bit too much...1:100 a bit too little and 1:80 perfect for 2-cycle snowblowers...weedwackers...etc.
The engine seems to start easier and run easy at full RPM. I was using Optimal which is a product made in W. Germany and it is not nearly as good but was better than conventional oils.
Old 08-31-2005, 02:27 PM
Firewalker
The merc prem plus for the 300x and the like is a fine oil, for the Hi-per oil they want you to use there Hi-per oil, it is nothing more than spectro golden.
In both cases you can improve.
RT
Old 08-31-2005, 02:31 PM
FYI
RP 2-cycle is $5.00/qt in 55 gallon drums...
Old 08-31-2005, 02:32 PM
Firewalker
I personally have no experience with Royal Purple, but I know those that do...... run Amsoil first.
RT.... don't rule out Alisyn....... the stuff ROCKS
Old 08-31-2005, 02:33 PM
It would be fun to see Alisyn 20W-50 and 2-cycle oils sent to Blackstone...a virgin test is what we need to make an informed decision with.
Old 08-31-2005, 02:39 PM
I use AMSOIL in my drives and Alysin in my motors. My guess is all the really good oils are similar in performance. It's the change intervals and use that make or break.
deboatmon is offline
Old 08-31-2005, 02:43 PM
I would have to agree to a point...I just wonder why Mobil-1 20W-50 seems to run offshore engines 10 degrees cooler on average with better pressures as well than even a non-premium synthetic...we don't see this with other oils to this extent ya know..
Old 08-31-2005, 02:55 PM
Any Amsoil dealers here..?
Quick Reply: Amsoil Products
