Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Registered East Coast B's Avatar
    Join Date
    Jun 2001
    Location
    Lehigh Valley, Pennsylvania
    Posts
    1,565
    Question Where can I get a water pressure sender and gauge?
    I'd like to hook up a water pressure guage with sender.
    Where can I find the parts?
    I have twin 1994 454 mags, where would the sender go?
    Most importantly, how can I hook the gauge to an audible alarm??
    Thanks!!!
  2. #2
    271 Fastech Gold Member Grog's Avatar
    My Boats:
    1999 Formula Fastech 271
    Join Date
    Jul 2003
    Location
    Peoria, AZ
    Posts
    240
    Re: Where can I get a water pressure sender and gauge?
    I know of no water pressure gauges that have an audible alarm built in. My water pressure gauge is from Gaffrig. It is mechanical (as far as I know they all are) so there is no sender. It uses a small nylon tube connecting the gauge to a brass fitting at one of the drain plug locations in the side of the block.
    Water pressure gauges are a good thing. Especially if you are running a blower.
  3. #3
    Join Date
    Jan 2001
    Location
    ST. Louis, MO, USA
    Posts
    1,658
    Loke Grog said, most are mechanical. You can hook the nylon tubing into the water passage on the intake manifold.
    My $0.02. Get a mechanical guage. Buy an adjustable Hobbs switch through Summit or Jegs, and wire your existing alarm to that.
    Gary
  4. #4
    Join Date
    Jul 2004
    Location
    SENECA LAKE
    Posts
    171
    Banana Re: Where can I get a water pressure sender and gauge?
    I would like to install a water pressure Gauge but where do you install the tube with closed cooling. I want to know if the impeller is starting to give up. Alpha drive.
  5. #5
    Join Date
    Jan 2001
    Location
    ST. Louis, MO, USA
    Posts
    1,658
    Hmmm, good question. Most closed cooling systems run thier raw water pressure much lower than the block pressure. I would put it as close to the water pump as possible and see what it reads. I'll bet your oil/power steering cooler has a 1/8" NPT plug to drain the water out. Try there.
    Gary
    Quote Originally Posted by Badtoon
  6. #6
    Join Date
    Jun 2001
    Location
    Posts
    1,565
    I like the hobbs switch idea....
    The switches come in various pressure settings from factory.. what are the pressure ratings min and max for the 454 cooling system??
    Here's a link to the hobbs switch page.. http://content.honeywell.com/sensing...scorp/P3_6.pdf
  7. #7
    Join Date
    Jan 2001
    Location
    ST. Louis, MO, USA
    Posts
    1,658
    Get an adjustable.
    http://store.summitracing.com/defaul...h.asp&x=36&y=9
    Try this:
    Check what your idle psi is hot (thermostat open). Then just adjust hobbs switch a couple psi lower.
    Gary
  8. #8
    Join Date
    Jun 2001
    Location
    Posts
    1,565
    To sum it all up.....
    I get a water pressure gauge i.e. gaffrig/lavorsi, mount gauge in dash and connect it to some location on engine i.e. block drain or thermostat housing.
    I then hook the pressure switch inline with the gauge and connect to my alarm.
    Not having climbed in my boat, but is there an available fitting on the thermostat housing already? Or must one be tapped in??
    I really like the idea of getting an alarm BEFORE my engine overheats due to a lost impeller.
    Thanks everyone for your assistance!!! This has been very helpful!
  9. #9
    Join Date
    Jun 2001
    Location
    Posts
    1,565
    Is this the type of switch needed?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
    It only goes to 30psi, not sure if water pressue goes that high though, I'm thinking it might work.... then again I'm not familiar with these things to know better....
  10. #10
    Registered Donman's Avatar
    Join Date
    Feb 2005
    Location
    Lake Texoma
    Posts
    914
    I just purchased a Gaffrig MECHANICAL water psi gauge from Triad Performance ( www.tpmarine.com ), $37 plus UPS. I did see an electrical one available somewhere....?
Similar Threads
  1. Water Pressure Gauge Sender??
    By Shah Mat in forum General Q & A
    Last Post: 06-02-2006, 08:36 PM
  2. where 2 mount my water pressure sender?
    By ratman in forum General Q & A
    Last Post: 08-02-2005, 06:40 AM
  3. Water temp sender/Oil pressure sender?
    By Danny_Ocean in forum General Q & A
    Last Post: 04-05-2004, 10:47 PM
  4. Wrong oil pressure sender?? Gaffrig gauge...
    By Waterfoul in forum General Q & A
    Last Post: 06-16-2003, 06:47 PM
  5. Wrong oil pressure sender?? Gaffrig gauge....
    By Waterfoul in forum General Boating Discussion
    Last Post: 06-15-2003, 08:18 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
