Searay with shingles what now? >
Old 09-16-2005, 02:26 PM
ratman's Avatar
Default Re: Searay with shingles what now?
all the shingles will make it a lot faster correct? the shingles will improve fuel econmy correct? where can i get some shigles for my cigarette, i'm gonna make my hull a stepped hull. how many packages of shingles will it take to make a quad stepped 35ft mistress? did they install them with screws or roofing nails with the little rubber orings to prevent leaks? if you get a tear in the seat will they use duct tape for the repairs? sounds like they didn't give much thought to your boats cg, and who wants to run a bunch of tab all the time? with only a single small block thats gonna cost you some speed and gas for as long as you own it. seems like a crapola bandaid job. i'd be pissed off and fighting to trade it in on a boat without a major design flaw. just my .02
ratman is offline
Old 09-16-2005, 02:37 PM
ratman's Avatar
on second thought you could rebalance the boat, get a fat girl to ride up front!
ratman is offline
Old 09-16-2005, 03:04 PM
JasonSmith's Avatar
I'd be out on the adding hook deal. Shingles as you call it. If Sea Ray could not put enought thought into designing the bottom of the boat how much thought do you think they put into the fix?
JasonSmith is offline
Old 09-16-2005, 03:09 PM
cuda's Avatar
I wouldn't accept the shingles as a fix.
cuda is offline
Old 09-16-2005, 03:14 PM
JasonSmith's Avatar
My uncle had shingles, he itched like a ***** for 2 months.
Old 09-16-2005, 04:35 PM
bouyhunter's Avatar
If you need to borrow a shingling gun, I've got one.
Should be able to lay 2 square an hour.
What pitch are you working on? 4/12 isn't bad. If you get into a 12/12 you're gonna need to get some "jacks" on there to get the shingles in the right place.
bouyhunter is offline
Old 09-16-2005, 05:04 PM
This is a serious question... Not a shingle one of you are funny right now!!!!!
blownboat is offline
Old 09-16-2005, 05:07 PM
birdog's Avatar
That is Pathetic !...Sea Ray should be ashamed
I like slate better anyway........................
birdog is offline
Old 09-16-2005, 09:06 PM
You guys are brutal!
Liberator21 is offline
Old 09-16-2005, 09:07 PM
21 and 42 footers
t500hps's Avatar
This is hilarious!!!! Where is Fund Razor? He is usually at the heart of these "episodes".
t500hps is offline
Quick Reply: Searay with shingles what now?
