Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-24-2005, 12:42 PM   #1
mats's Avatar
Baja 1988
Prop for 1988 baja 235 Force
Hi
I am trying to find a good prop for my 1988 Baja 235 Force.
It has a stock 1998 502 MPI with Gil Exhaust. Should give some 440 hp on the propshaft. The current prop is a 23 inch Mirage Plus. The engine revs 4700 rpm fully trimmed out. The top speed is about 60 mph on GPS. Seems low to me for this size boat.The boat weighs 3600 lbs +400 lbs gas and driver. Are there any better props for speed and/or handling?
mats is offline   Reply With Quote
Old 09-24-2005, 10:08 PM   #2
Whiteknuckle's Avatar
Sunsation Rocket
Re: Prop for 1988 baja 235 Force
You seem to be experiencing a lot of slip, about 19% by the calculator. Your horsepower estimate also seem a little on the optimistic side for the figures you are stating. I am no expert, but I would want to spin that engine up a couple hundred RPM more, and I think if you explain all the details to one of the good prop shops here on OSO they could lead you in the right direction. For top end, I think you will most likely stay with the Mirage. I don't know how your boat will respond to a 4-blade, that is why you should get the prop people involved.
Whiteknuckle is offline   Reply With Quote
Sponsored Links
Old 09-25-2005, 11:47 AM   #3
AIR TIME's Avatar
BAJA OL 650HP/ SABER 28 Gellner unlimited with konrad ace
try a rev 4 23p merc or a reg 23 p mirage not the plus I had a 502 390hp at the prop turned a reg 25p mirage at 4800rpm that was in a 24sport 88 4000lbs dry 67mph
AIR TIME is offline   Reply With Quote
Old 09-25-2005, 04:22 PM   #4
RBeyer's Avatar
1998 Velocity 280
21 Mirage Plus
RBeyer is offline   Reply With Quote
Old 09-26-2005, 01:46 PM   #5
throttleup's Avatar
Throttle Up Propellers Manufacturer
The 502 needs to run at 5000 RPM at WOT. What drives and gear ratio do you have?
Julie
throttleup is offline   Reply With Quote
Old 09-27-2005, 04:51 AM   #6
mats's Avatar
Baja 1988
Itīs a Bravo One Drive with 1.5:1 gear ratio
mats
Old 09-27-2005, 09:59 AM   #7
throttleup's Avatar
I have calculated your slip at 12% which is great for a 3B propeller. I would make one suggestion though the 502 needs to run at 5000 RPM at WOT as this is were the peak HP is produced on your motor and this is were peak top end is found. So you may want to owrk your propeller for the additional RPm or possibly try a 21P Mirage Plus.
Julie
Old 09-27-2005, 04:39 PM   #8
mats's Avatar
Baja 1988
Iīll try a 21 inch prop.
Mats
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Drive height, Baja 235 Force mats General Q & A 8 11-11-2006 02:33 PM
Drive height, Baja 235 Force mats Baja 0 11-09-2006 09:45 AM
First Boat Baja 235 Force ? brew80 Baja 0 08-01-2006 04:39 PM
Baja 32 force prop??? TIP-SEA_32_baja General Q & A 0 06-22-2005 01:29 PM
Check out my 1988 Baja Force 265 for sale on Ebay! cdaniel525 General Boating Discussion 0 12-21-2002 04:31 PM
Search Engine Optimization by vBSEO 3.2.0
